Brembo Hydraulic Clutch for an '07 - Kawasaki ZX-10R.net
post #1 of 12 Old 03-27-2007, 04:36 PM Thread Starter
Hi Everyone,
Just wondering if anyone has tried using a hydraulic clutch setup on the 10R? I find the clutch a lot heavier than the '06 R6 and Gixer 750. It's not a must have mod, but the idea of a lighter pull definately is tempting. Has anyone tried a hydraulic clutch before?
I found this link for Ducati's and wonder if the Brembo unit can be fitted onto an '07.
1. http://www.ducatimeccanica.com/MMC/c...onversion.html Duc Kit
2. http://www.redracingparts.com/en/eng...reservoirs.php Some Brembo radial pumps
Did a search, and didn't find anything on the subject. Any info would be appreciated. Thanks in advance.
Kagetsuya is offline
post #2 of 12 Old 03-27-2007, 06:09 PM
MSR clutch mod
Get the MSR universal clutch perch/lever cheap $35 and lowers the lever pull alot.Hell tommy hayden ran it last year and so did the wsbk boy's.
wildeman is offline
post #3 of 12 Old 03-27-2007, 06:14 PM
ninja2k5's Avatar
ninja2k5 is offline
post #4 of 12 Old 03-27-2007, 08:02 PM
Mustard's Avatar
Any pics of the msr clutch lever?
Once i thought more than two strokes was masturbation. Now I realise that 4 feel better, and who am I to argue with my feelings.
05 Black/white road/track zx-10r. Race fairings with stock headlight custom blinkers, Brembo MC, HEL braided lines, Toby dampner, Mustard Block-off plates, plugged airbox, Mustard Heel guards, Mustard Ram-air tube support, custom flip-up rear fender eliminator, custom rear fender, custom seat cowl, corsa 111's.
Mustard is offline
post #5 of 12 Old 01-07-2009, 06:41 PM
Bigprfed22's Avatar
Images: 93
crg supersport or gp clutch perches
"Bs stops when the green flag drops"
Bigprfed22 is offline
post #6 of 12 Old 01-07-2009, 07:25 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Would take quite a bit of fabrication to convert a cable clutch to a hydraulic, not even sure if it is feasable/possible.
9R to 10R is offline
post #7 of 12 Old 01-07-2009, 07:39 PM
Bigprfed22's Avatar
Images: 93
possible but not worth it, and you get more feel out of a cable clutch regardless.
post #8 of 12 Old 01-07-2009, 07:54 PM
Gone Ridin'
twidget's Avatar
Send a message via AIM to twidget Send a message via MSN to twidget Send a message via Yahoo to twidget
You can find a discussion on the MSR lever here: https://zx-10r.net/forum/showthread.p...r+clutch+perch
I have one and it is certainly well worth the 30 bucks or so you spend on it. The difference is not really in the lever, but the perch and the adjuster. It could be a bit shorter to suit me, but for the price...
twidget is offline
post #9 of 12 Old 01-07-2009, 08:03 PM
Bigprfed22's Avatar
Images: 93
True, the crg supersport is what i use and it is super light and adjustable just a little pricey if you dont get it at cost.
post #10 of 12 Old 01-07-2009, 08:05 PM
flthy1's Avatar
Originally Posted by ninja2k5 View Post
:crac kup:
flthy1 is offline
CRG Clutch Blk Clutch Lever & Lightech Gas Cap yehzx10r Vendors deals 2 09-25-2006 05:25 PM
brembo rocketracermike Performance and Tech 10 02-27-2006 06:47 AM
04/05 ZX10R Hydraulic Clutch Conversion? Larry Grogan The ZX-10R 11 02-22-2006 10:23 PM
slipper clutch & clutch plates... jarhead05 Performance and Tech 14 07-07-2005 03:13 AM
rear hydraulic brake switch for the 10R-$15 shipped steves87 Parts, Gear and Accessories 6 05-20-2005 05:04 PM
