brembo front discs. - Kawasaki ZX-10R.net
post #1 of 3 Old 03-07-2010, 04:33 PM Thread Starter
brembo front discs.
hi,at the mo i am running brembo calipers on factory 300mm discs on my 2nd gen,i also run the brembo rcs master cylinder with braded lines.
if i bought the brembo 320mm front discs will it improve my braking power much more than now?and what size caliper spacers will i need..cheer's.
ps,are the 320mm clubman brembo discs as good as the 320mm hpk brembo discs??.
krakers10r is offline
post #2 of 3 Old 03-08-2010, 01:14 PM Thread Starter
bump,anyone????????
post #3 of 3 Old 03-08-2010, 03:52 PM
snipes285's Avatar
I replaced my m/c, disc's and calipers all to Brembo and went with the oversize 320mm floating discs. Stopping is no longer a guessing game as compared to the stock set up.
My spacers are 10mm.
Not sure if the 320mm are that much better then a 300mm set up but I wanted the most stopping power of the two (larger discs typically will have better stopping power but also have a weight disadvantage).
Hope this helps...
snipes285 is offline
WTB Front Brake Discs, 06/07 10R SUPER K Wanted: Buy or Trade 1 03-04-2010 10:18 PM
Brembo front master 325.00 shipped avdigigeek Parts, Gear and Accessories 10 01-23-2010 05:48 PM
Need to replace front discs - any advice kwack Performance and Tech 8 08-06-2009 04:55 AM
FS: Brembo Discs, 04-07 ZX-10R, 03-09 ZX-6R loki-10R Parts, Gear and Accessories 4 07-16-2009 11:05 PM
WTB: zx10r 320mm brembo front rotors Lyzic Vendor Deals 2 05-10-2006 01:44 PM
