Gen 1: 2004-2005 Brembo calipers - Kawasaki ZX-10R.net
post #1 of 9 Old 06-25-2012, 06:01 AM Thread Starter
TomMurray's Avatar
Brembo calipers
Thought it might be nice to try a set of the M4 Calipers for my 05 ZX... I know they're not the best of the bunch, but they will be better than stock.
Just wanted to get an idea of which lines might be best suited to this particular caliper.
Any thought?
15 S1000RR:Black, HP wheels, HP rearsets, HP levers, BMW screen, seat cowl.
05 Titanium ZX10R: Full Akra Evo,Ohlins shock,AK20 carts,19RCS/M4.
05 R1: Full Micron Ti,PCIII,K&N,Ohlins damper-25mm's-shock,BST's,520 kit.
98 CBR900RR: DJ jet kit,Akra slip on.
63 R50: RIP Grand-dad.
09 CBR1KRR: Sold
05 ZX10R: Write-off
96 CBR600F3: Sold
10:10
TomMurray is offline
post #2 of 9 Old 06-25-2012, 06:13 AM
All show and all go 10r
JLG0987's Avatar
ok first off what is your current brake setup. I'm assuming SS line and the 19 RCS? What fluid are you using? How Aggressive are you being with your brakes and how often(corner and corner or the odd corner on the street?
JLG0987 is offline
post #3 of 9 Old 06-25-2012, 06:23 AM Thread Starter
TomMurray's Avatar
Yeah, currently running with the 19RCS, Goodridge lines (in stock configuration), Galfer HH sintered pads and can get on the brakes fairly hard...
I was wondering if a line per caliper would work better, and which lines will have the best fit for the brembo calipers (as I noticed they attach to the stock calipers at the middle of the caliper and on the brembo's at the top of the caliper).
09 CBR1KRR: Sold
05 ZX10R: Write-off
96 CBR600F3: Sold
10:10
post #4 of 9 Old 06-25-2012, 06:32 AM
JLG0987's Avatar
I've only even ran aftermarket lines 2 from MC to each caliper so I can't answer that for you. Safe to say It wouldn't make a big difference especially for the cost of new lines. If you do get calipers and the banjo bolts are located differently you'll just have excess line which might be fine, usually only a rubbing issue or looks if that bothers you. Calipers are cheap and I've talked to a few people that have used M4s and nissins and say they are practically the same. Nissin's had better initial bite.
If you're willing to drop that much coin I think a far better option would be to get nissin calipers, upgrade the rotors from 300mm to 310mm and the proper spacers for the calipers. Don't forget longer bolts. It would be about the same or less depending on what rotors you go with and give you FAR more performance for your money.
JLG0987 is offline
post #5 of 9 Old 06-25-2012, 07:21 AM Thread Starter
TomMurray's Avatar
Hmmm. I have been tossing up running a set of '08 CBR1000 calipers with (5mm?) spacers to see what difference I get.
09 CBR1KRR: Sold
05 ZX10R: Write-off
96 CBR600F3: Sold
10:10
post #6 of 9 Old 06-25-2012, 09:01 AM
RPG76's Avatar
+1
Running the RCS/Nissin combo and it is great.... But larger disks would take it to the next level for sure. R1 calipers (2007 I think?) get good reviews as well.
05 ZX10r "the Mongrel": GP Suspension rebuilt forks, LE Penske double shock, 05-06 ZX6rr shock linkage, Brembo RCS MC, Nissin calipers (best mod for this bike!!!), Attack rearsets, Motion Pro Revolver throttle kit, ASV clutch lever, Champs sliders, smoked Zero Grav DB, Ti caliper bolts, CF fender, Renthal grips, Speedo healer, Maviryk MDA123 batt, Supersprox +3 520, That's it..... For now
190/55>190/50
RPG76 is offline
post #7 of 9 Old 06-27-2012, 06:13 AM Thread Starter
TomMurray's Avatar
Thanks for the info. So is there a set of lines that will fit up to the brembo calipers better than others at all?
09 CBR1KRR: Sold
05 ZX10R: Write-off
96 CBR600F3: Sold
10:10
post #8 of 9 Old 06-27-2012, 06:25 AM
JLG0987's Avatar
doesn't work like that. It's just length.
JLG0987 is offline
post #9 of 9 Old 06-27-2012, 03:21 PM
Post Whore
-Op-'s Avatar
yup. the banjos are all universal. the only thing you have to make sure of is having enough slack in the lines. I put CBR600RR calipers on mine with 5mm spacers. Same caliper as the 1kRR, theyre much nicer than the original stuff. I went from ZX6R radial M/C, stock lines stock calipers to same M/C with Hel SS lines and 1kRR lines and the braking is pretty freakin good. I do need new pads though
-Op- is offline
Anyone tried the Brembo GP4 RX Calipers? 9R to 10R The ZX-10R 20 12-29-2011 06:59 AM
brembo calipers on ebay fbmbks Parts, Gear and Accessories 11 05-08-2009 09:16 PM
brembo calipers... malentendu arete Performance and Tech 8 07-01-2007 06:33 PM
Brembo HP calipers Lvninja Performance and Tech 4 06-12-2007 09:59 PM
Brembo calipers? maze Performance and Tech 14 01-11-2006 04:09 PM
