Brembo & brake lines - Kawasaki ZX-10R.net
post #1 of 10 Old 01-10-2006, 07:03 AM Thread Starter
Hi guys, I was wondering if I can use the Galfer braided lines that are on my ZX10 now with a new Brembo radial master cylinder.
The bike also has Heli Bar risers.
Thanks Otto
Tell your girlfreind I said thanks
otto is offline
post #2 of 10 Old 01-10-2006, 07:37 AM
41ants's Avatar
I have the brembo radial MC with galfer lines... The heli risers might be a problem because the lines might not be long enough. Install and put the front up on a tree stand and test the length. If it looks good then fill the lines with fluid and enjoy
05' ZX-10R (sold)
03' 954RR Titanitum/Black (sold)
41ants is offline
post #3 of 10 Old 01-10-2006, 07:58 AM
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
It will work but not with the banjo bolt that galfer supplies. Do not put the galfer banjo bolt into the brembo m/c. The pitch is wrong and it will strip and ruin the m/c causing it to leak. Make sure you buy a banjo bolt that goes with the brembo mc. And yes I am speaking from experience. Oh yeah I am not sure if the lines will be long enough.
zx10ragentblack is offline
post #4 of 10 Old 01-10-2006, 08:22 AM
Big Daddy's Avatar
Images: 38
hmmmmmmmm, since the lines mount to a radial differently would that cause any probs??
Big Daddy is offline
post #5 of 10 Old 01-10-2006, 08:31 AM
Yankee Racer
Images: 9
I have the brembo mc with galfer lines and it works fine, just gotta do a little adjusting to get everything lined up. No prob. I am still not sure if the lines will ne long enough with the helibars??
post #6 of 10 Old 01-10-2006, 01:46 PM
Rspec99's Avatar
Images: 11
I have the same set up, with the Galfer SBK lines and Brembo MC. It is a tight fit with the lines, but I believe there is just enough slack in the lines. I think with the risers there may not be enough slack.
Rspec99 is offline
post #7 of 10 Old 01-10-2006, 02:41 PM Thread Starter
I quess I want to know if when you put on the Brembo Radial m/c,did you have to use a different set of lines? Or did the lines you had with the stock m/c work? I have the Galfer (not superbike) lines with the stock m/c.
otto is offline
post #8 of 10 Old 01-10-2006, 04:41 PM
I think zx10ragentorange already answered this one.
lochendorb is offline
post #9 of 10 Old 01-11-2006, 07:45 AM
Again, yes. This is the same setup I run. Brembo m/c with Galfer lines for the stock m/c. You may need to rotate the banjo fittings a bit to line things up, but they work just fine.
CanyonCarver is offline
post #10 of 10 Old 01-11-2006, 10:22 AM Thread Starter
Thanks all .
otto is offline
Replacing Brake Lines, Fluid, and Bleeding zx102nv Performance and Tech 20 10-21-2009 05:58 PM
Brembo MC 19x18 and SS brake lines Tito Vendors deals 32 12-29-2005 03:07 PM
Replacing Brake Lines, Fluid, and Bleeding zx102nv How To... 1 01-10-2005 03:27 PM
MD Product Review: Galfer's Sintered 1375HH Brake Pads and Brake Lines and Waves flatout Performance and Tech 4 11-04-2004 12:29 PM
Member Special: Galfer SS Brake Lines & HH Pads Cal-Sportbike Vendors deals 8 07-31-2004 11:11 PM
