brembo 19x18 question - Kawasaki ZX-10R.net
post #1 of 8 Old 08-11-2007, 11:12 AM Thread Starter
EAST-LOS's Avatar
I just bought a Brembo master cylinder and I have already the SS Galfer lines but I haven't installed yet.because some people say that I need new lines. what do you guys think do I need new lines or the ones I have are ok.
2005 ZX10R
EAST-LOS is offline
post #2 of 8 Old 08-11-2007, 11:26 AM
Big Daddy's Avatar
Images: 38
Since the mounting angles are different between radial MC's and conventional MC's its very possible you'll require lines to fit the specific MC.
I forget what year 10 you have but if its an 06,7 that has the OEM radial they may fit but if not then yes new ones.
Big Daddy is offline
post #3 of 8 Old 08-11-2007, 11:38 AM
Stretchy's Avatar
I have galfer lines on my racebike and changed from stock mc to brembo mc with no problems.
Black and Green 05 ZX10R - Race Bike
Stretchy is offline
post #4 of 8 Old 08-11-2007, 11:40 AM
Big Daddy's Avatar
Images: 38
do you have a pic of the routing & mounting???
post #5 of 8 Old 08-11-2007, 12:01 PM Thread Starter
EAST-LOS's Avatar
you mean that you had the lines install before the Brembo mc and they work.
EAST-LOS is offline
post #6 of 8 Old 08-11-2007, 01:27 PM
I had Goodridge lines on my '99 R1 before the Brembo and didn't have any problems fitting them, I think I gained a bit of slack as the lines mount lower on the m/c. The thing to remember with the Brembo swap is you'll need a Brembo reservoir and fluid line, and Brembo compatible banjo bolt, the thread is different but it fits the banjo on the lines ok. I got a banjo bolt with a built in brake switch to save having to make the original fit.
doug_uk is offline
post #7 of 8 Old 08-11-2007, 04:56 PM
WOODYZX10R's Avatar
i have not done mine yet, but Trey used his old lines with a new brembo. if you have speigler lines you can turn them.
2004 ZX10R, mostly kinda stock
WOODYZX10R is offline
post #8 of 8 Old 08-11-2007, 09:13 PM
Stretchy's Avatar
Yes here is the pics. Had the lines first with stock mc and now with brembo.
Had to rotate to get a good pick but shows you how it looks.
Name:	Brembo - galfer 002s.JPG
ID:	41901   Click image for larger version
Name:	Brembo - galfer 001s.JPG
Stretchy is offline
W.T.B. Brembo 19X18 Master Cylinder circusnuts Vendors deals 3 04-05-2007 06:25 PM
Brembo 19x16,19x18,19x20 which to use? zx10hellcat Performance and Tech 20 08-06-2006 12:39 AM
Brembo 19x18 - Additional Parts Needed? JLove Performance and Tech 13 05-06-2006 01:27 AM
Brembo MC 19x18 and SS brake lines Tito Vendors deals 32 12-29-2005 03:07 PM
Brembo 19x18 brake master flatout Vendors deals 12 06-23-2005 07:46 AM
