brake mysteries - Kawasaki ZX-10R.net
post #1 of 24 Old 08-18-2007, 08:26 PM Thread Starter
norcal10's Avatar
brake mysteries
ok guys, here goes. i installed my 636 master/calipers about 2 months ago. used it for 2 trackdays, no fade at all either time. bled them thuroughly after the 2nd day. have dot5 fluid in them. stock lines, stock pads. they have been AWESOME from day one. then, wednesday going to work, i go to back down the driveway and almost crash, no brakes. lever went to the bar, no resistance at all. i pumped it up, and it was fine. rode to work, and by the time i got to work (about 3 miles) it was normal. then it was fine for two days. this morning, same damn thing, no lever whatsoever. this time, i pumped it up a lot, it didnt get much better. i rode to work (shouldnt have probably) and it never got to the same feel as before. then when i came out from work to ride home, solid as a rock. coming home on the freeway, with no traffic around, i grabbed a handful of front brake and it was like hitting a wall, just like before this happened. what the hell is going on here?!? i'm ase certified in suspension and brakes, and i have no idea on this!! i suppose my master could be bad, but i've never seen a master be bad sometimes, then just fine, that just doesnt make sense. help me out guys, i'm going to the track in a couple week, wanna make sure i'm dialed in. tia.
norcal10 is offline
post #2 of 24 Old 08-18-2007, 08:35 PM
Chickenstrip Eater
SUPER K's Avatar
Send a message via MSN to SUPER K
H2O, in the lines? Hydraulic fluid draws moisture. Is the res lid on tight? Are all the bajo bolts tight and sealed?
http://i117.photobucket.com/albums/o45/josh10r/IMG_0144-1-1-1.jpg
Sent from your mom's IPhone using dirty fingers
SUPER K is offline
post #3 of 24 Old 08-18-2007, 08:37 PM
SalKhan's Avatar
Send a message via AIM to SalKhan Send a message via Yahoo to SalKhan
Dot 5? Or 5.1?
Sal Khan
http://www.thelunchjournals.com - Updated 3/8/08!
SalKhan is offline
post #4 of 24 Old 08-18-2007, 08:57 PM
technic's Avatar
The pistons are retracting into the caliper too much at some point, can happen if you get a front wheel shake/tankslapper etc
technic is offline
post #5 of 24 Old 08-18-2007, 08:58 PM
thrill's Avatar
Possible air pocket in the crossover line??
Bill - GI Pro, Hindle slip on, Smoked screen, ZX14 brakes.... Well, you feel lucky, punk? You shouldn't, this is a 10R
thrill is offline
post #6 of 24 Old 08-18-2007, 09:38 PM Thread Starter
norcal10's Avatar
i should have added that everything is totally dry, no fluid leaks anywhere. see, if there was air in the lines, it wouldnt get "better" by sitting. i really am stumped here. i will try to bleed it tomorrow morning.
norcal10 is offline
post #7 of 24 Old 08-18-2007, 09:40 PM Thread Starter
norcal10's Avatar
never had anything like a front wheel shake at all. occasional wiggle in the bars, but thats it! i dont think the pistons are retracting as i can still hear the pads dragging slightly on the rotor. also, the level of the fluid doesnt change, it stays right at the upper line.
norcal10 is offline
post #8 of 24 Old 08-18-2007, 11:37 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
I would guess your pistons are sticking on one of your calipers.
9R to 10R is offline
post #9 of 24 Old 08-22-2007, 10:51 PM Thread Starter
norcal10's Avatar
update:
so last night i bled the whole system. my dot5 fluid had changed from a nice deep purple to a slightly-tinted-purple clear. so i bled it all out, couldnt get the lever back at all. zip-tied it to the bar, came out this morning, got no air out of it. rode it to work anyways, the fronts still stop me, but the lever comes to the bar easily. come out of work and the lever is solid as can be. i start riding, and every time i pull on the lever, it gets a little worse. WHAT THE HELL IS GOING ON? do i need to/can i rebuild my master cyl? i dont know what to do... thanks guys.
norcal10 is offline
post #10 of 24 Old 08-22-2007, 11:08 PM
bkkninja's Avatar
Sounds to me the seal in your cylinder may have gone hard.
bkkninja is offline
to brake or not to brake norcal10 Performance and Tech 8 04-08-2007 12:31 PM
04/05 10r -Pazzo (brake) and Goodridge SS brake lines JBJ Parts, Gear and Accessories 1 02-14-2007 10:15 PM
Brake lines and brake pads DareDevil Vendors deals 1 09-30-2006 08:49 PM
Brake Pad Bed in. hillcountry10r Performance and Tech 20 09-28-2005 12:16 PM
MD Product Review: Galfer's Sintered 1375HH Brake Pads and Brake Lines and Waves flatout Performance and Tech 4 11-04-2004 12:29 PM
