Brake MC question - Kawasaki ZX-10R.net
post #1 of 3 Old 08-17-2010, 06:19 AM Thread Starter
Brake MC question
I found out that certain years R1/6s came with brembo master cylinder. My question is has anyone ever done this before...ie any fitment issues...clip on lever...etc? I have access to one at a real good price so just inquiring before i go spending $$. Thanks.
dvls-10 is offline
post #2 of 3 Old 08-17-2010, 02:57 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
Almost all modern sportbikes use the same diameter clipons so any master will be able to be swapped from one year-make-model to another. i knew they that certain years used a brembo rear master but didn't know about the front, if you're using this on the 2nd gen 10 then it might be a downgrade from the stock radial master...just cause it says brembo doesn't mean it's the bestest one out, just ask the folks who have had to upgrade or replace their ohlins damper on the 2nd n 3rd gen 10's.
TMY10ER is offline
post #3 of 3 Old 08-18-2010, 05:02 AM
ducatiryder89's Avatar
Images: 21
Be careful just because its a Brembo doesn't mean it will work. Yamaha's use a very small pistons on their calipers. Stock Yamaha master cylinders I believe 16mm bore meaning it pushes less fluid. Stock Kawasaki radials are 18mm bore.
ducatiryder89 is offline
another brake question zx10r85 Performance and Tech 4 10-19-2007 11:49 AM
Brake Pad Question??? zx10ragentblack Performance and Tech 8 05-10-2007 10:51 AM
06/07 brake question shenanigans The ZX-10R 7 03-26-2007 04:58 AM
Brake pad Question? KaTooM Performance and Tech 3 05-22-2006 09:00 PM
Brake Question barryblanken The ZX-10R 1 01-27-2006 10:33 AM
