Brake lines hitting throttle cables - Kawasaki ZX-10R.net
post #1 of 18 Old 01-05-2009, 10:06 PM Thread Starter
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
Well... I had this for a while since I replaced my MC with a Radial one.
I have an 05 and the its a tight fit having the throttle cables and the brake lines all in the same spot.
I have seen people rotating their throttle assembly (housing)...
Im wondering how this is done...
Is it as simple as just rotating it ?
There is a small tit on the housing that goes inside the small hole to prevent the housing from rotating...
Do I just need to rotate the housing and drill a new hole for the tab/tit ?
What am i missing here ?
THanks
Lucky10R is offline
post #2 of 18 Old 01-05-2009, 10:31 PM
bird_dog0347's Avatar
Images: 11
I think the solution Goldfish had for his was to get new 2008 braided brake lines, but he also had to remove the right side switches and put them up by the dash. Really cool how he got it to work since he changed out the clip ons, the radial MC, brake lines, and moved the starter and kill switch to the dash panel. Maybe he can chime in to help out.
bird_dog0347 is offline
post #3 of 18 Old 01-05-2009, 10:49 PM
Retired post whore
Alien10's Avatar
I had the same issue when I installed a ZX-14 radial master on my 04. It will fit, you just have to move the brake lines around a bit. I can take a pic tomorrow of how mine are routed if you need it.
Alien10 is offline
post #4 of 18 Old 01-05-2009, 10:51 PM Thread Starter
Lucky10R's Avatar
Images: 19
I dont think I have to do all that.
I have seen people running it differently.
They rotate the throttle housing upward to the cables exit on top and not at the bottom.
I think I can do it but Im just making sure Im doing it right.
Lucky10R is offline
post #5 of 18 Old 01-05-2009, 10:53 PM Thread Starter
Lucky10R's Avatar
Images: 19
Yes it fits.. as I am running it right now.
The only reason Im doing this is that I've seen better solutions.
Im also using SS brake lines for GEN 2 since they already have radials.
Gen 2 brake lines are much shorter than GEN 1 so I can only route the brake lines with little options.
Lucky10R is offline
post #6 of 18 Old 01-05-2009, 10:54 PM
Retired post whore
Alien10's Avatar
Do all what? Loosen the brake lines at the banjo bolt where they bolt into the radial. They can be moved so they don't touch the throttle cables.
Alien10 is offline
post #7 of 18 Old 01-05-2009, 10:56 PM Thread Starter
Lucky10R's Avatar
Images: 19
I was replying to bird_dog0347 :)
You just replied right away (damn that was fast)
Lucky10R is offline
post #8 of 18 Old 01-05-2009, 11:00 PM
Retired post whore
Alien10's Avatar
I gotcha. Just trying to help - I pulled my hair out trying to get everything to fit just right when I was doing mine. I think I may have loosened the throttle housinf as well - it will move just a tiny bit.
Alien10 is offline
post #9 of 18 Old 01-05-2009, 11:03 PM Thread Starter
Lucky10R's Avatar
Images: 19
this is what I mean
Lucky10R is offline
post #10 of 18 Old 01-05-2009, 11:05 PM
Retired post whore
Alien10's Avatar
On my 04 I kept the cables routed under the radial. I never tried to take the throttle off and route like my 08. It would make more sense and life a bit easier.
Alien10 is offline
WTB '05 throttle cables 2fast10 Wanted: Buy or Trade 0 03-26-2008 05:18 PM
Longer Throttle Cables? semozx10 Performance and Tech 4 11-20-2007 06:26 PM
06/07 Throttle cables brian0128 Vendors deals 2 06-05-2007 12:18 PM
Stock 06/07 throttle cables brian0128 Wanted: Buy or Trade 2 03-18-2007 01:53 PM
Throttle cables adjust. Zxrider The ZX-10R 7 09-04-2004 06:27 PM
