Brake lines - Kawasaki ZX-10R.net
post #1 of 9 Old 12-24-2008, 11:29 AM Thread Starter
slav's Avatar
Send a message via AIM to slav
Brake lines
Installed my Galfer lines and put the line that crosses over to the left side the wrong way. I like the way the lines run up together;cleaner. Does this matter or can I leave it? I want to get the most out of theme, so if I need to, I will switch it.
slav is offline
post #2 of 9 Old 12-24-2008, 09:48 PM
Bayboy's Avatar
Send a message via Yahoo to Bayboy
I had the same issue when I installed my brakelines. While speaking to the Galfer rep, he informed me that configuring the lines like the stock ones were(piggy back) was the wrong set-up. There should be line per caliper.
YES, I KNOW YOUR BIKE IS FAST............ BUT IS IT FAST WITH YOU ON IT!!!!
Bayboy is offline
post #3 of 9 Old 12-24-2008, 09:51 PM
Originally Posted by bayboy View Post
i had the same issue when i installed my brakelines. While speaking to the galfer rep, he informed me that configuring the lines like the stock ones were(piggy back) was the wrong set-up. There should be line per caliper.
BIKERZX10R is offline
post #4 of 9 Old 12-24-2008, 09:54 PM
Bigprfed22's Avatar
Images: 93
Depending how aggressive you are on the brakes, street or track. Track you def want one line per caliper meaning a double banjo up top. The cross-over line in the stock setup kind of creates a slight lag and uneven pressure.
"Bs stops when the green flag drops"
Bigprfed22 is offline
post #5 of 9 Old 12-25-2008, 08:54 AM
Supercharged Mod
The cross-over line is a bugger to bleed ... it will always want to have an air bubble at the top of the loop.
GoFaster is offline
post #6 of 9 Old 12-25-2008, 06:43 PM Thread Starter
slav's Avatar
That would he the natural way. I'm going to change it to the one per each. Thanks guys
slav is offline
post #7 of 9 Old 01-10-2009, 02:45 AM
I have a set of Gaflers im getting ready to install and want to make sure I don't do this but I don't understand the difference.... Don't you just set them up the same as the stock ones?
alexs750 is offline
post #8 of 9 Old 01-10-2009, 03:12 AM
Quick10's Avatar
No...run each line directly from the caliper to the master cylinder
Quick10 is offline
post #9 of 9 Old 01-10-2009, 09:16 AM Thread Starter
slav's Avatar
Much better, just remember to bleed from master.
slav is offline
Looking for brake lines Blink180Wilhelm Vendors deals 1 09-27-2007 06:14 PM
04/05 10r -Pazzo (brake) and Goodridge SS brake lines JBJ Parts, Gear and Accessories 1 02-14-2007 10:15 PM
Brake lines and brake pads DareDevil Vendors deals 1 09-30-2006 08:49 PM
Need Help Brake Lines hangman39 Wanted: Buy or Trade 9 09-18-2006 05:53 PM
MD Product Review: Galfer's Sintered 1375HH Brake Pads and Brake Lines and Waves flatout Performance and Tech 4 11-04-2004 12:29 PM
