Gen 3: 2008-2010 Brake light fuse popps after two minutes of riding - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By SkyDork
  • 1 Post By ddipaola
post #1 of 3 Old 08-17-2018, 10:12 AM Thread Starter
Ok sports, i just baught a gen 3 zx10r and about a week after taking it home the breaklight went out and got pulled over before i realised. I can change the fuse and it will work just fine untill i ride for a bit. Then it poppes randomly....
Any ideas or experiences?
Thanks
jake890394 is offline
post #2 of 3 Old 08-17-2018, 11:03 AM
SkyDork's Avatar
Welcome.
Yeah, we need a little more info than that. If the fuse pops, then you have an electrical problem. Obviously. The power is shorting to ground and drawing too much amperage through the fuse. That's not typical for that model of bike, so you need to troubleshoot the issue.
Is it the stock OEM taillight in there or has it been replaced to an aftermarket one? Do the turn signals work? Does the license plate light work? Have you unplugged it and checked the connector? Any obvious signs that the wiring is melting is certain spots? Any other issues with the bike?
dudewhrsmybike likes this.
#WordCrimes
SkyDork is offline
post #3 of 3 Old 08-17-2018, 12:51 PM
ddipaola's Avatar
Thanks
Did the fuse pop (light discoloration) or blow up (heavy black discoloration)?
michael4012 likes this.
When in doubt... send it!
ddipaola is online now
Brake Light Fuse Problems!!!! GCE-ZX10R Performance and Tech 0 05-29-2010 08:46 AM
Fuse for parking and brake light? narc300c Performance and Tech 2 04-29-2010 07:54 PM
Question re correct Fuse after HID conversion Esta56 The ZX-10R 6 11-21-2008 04:48 PM
need help!!!blowout the ECU fuse after walbro installed plasticbaby Performance and Tech 18 12-03-2007 12:13 PM
Wrecked my 10 30 minutes ago! Austin10RPowers The ZX-10R 42 02-28-2005 03:36 AM
