brake fluid recomendations? - Kawasaki ZX-10R.net
post #1 of 16 Old 07-16-2005, 09:31 AM Thread Starter
avdigigeek's Avatar
Hey all,
I'm going to install braided lines today.
Anyone have any suggestions for the fluid.
I have some dot 4 maxima stuff, and thats what I usualy use.
The reason I ask is its the same fluid I've been using in my track bike and dirt bike.
I've noticeed brake fade in my track bike not sure if it's the fluied or pads etc...
I'm curious what other folks have had good luck with...
Thanks in advance.
Smiley
nesba # 936 http://www.nesba.com/
CCS # 936 wingnutzracing.com
Sponsors
Twisted-powersports.com
DCDECALS.net
http://ask2geeks.com/
http://www.superbikeitalia.com/
"Being shot out of a cannon will always be better than being squeezed out of a tube.
That is why god made fast motorcycles"
Hunter S. Thompson.
avdigigeek is offline
post #2 of 16 Old 07-16-2005, 10:03 AM
Any DOT 4 will work. Brake fluid doesn't affect brake fade. When your fluid boils the brakes just go away.
swjohnsey is offline
post #3 of 16 Old 07-16-2005, 10:52 AM
RickRoush03's Avatar
Put the MOTUL 600 in mine, and Castrol in DB's, both seem to work great.
"Lead, Follow, or get the hell outta my way!!"
Blue 2004 ZX-10R
- 152.5rwhp 77.6rwtq - more than I need
Red 2003 Jack ROUSH Classic #8 of 50
- 375rwhp 381rwtq
RickRoush03 is offline
post #4 of 16 Old 07-16-2005, 11:13 AM
Post Whore
El Diablo's Avatar
Moved to tech section
"Bottom line, when I'm on that bike, it's just me and God...And He better be holding on."- Stillie on SSB
Si vis pacem, para bellum...
El Diablo
El Diablo is offline
post #5 of 16 Old 07-16-2005, 03:04 PM
rocketracermike's Avatar
i have them on my bike. i put sny in mine. they work and look sweet at the same time.
rocketracermike is offline
post #6 of 16 Old 07-16-2005, 03:29 PM
Whatever you do, don't use car brakefluid in a motorcycle . . . it will make yer clutch slip!
post #7 of 16 Old 07-16-2005, 03:35 PM
Big Daddy's Avatar
Images: 38
Motul RBF600 and Castrol SRF and both very good.
Big Daddy is offline
post #8 of 16 Old 07-16-2005, 03:41 PM
I use the Valvoline stuff because it is cheap and available. Notice the difference in the wet and dry boiling point. Change your brake fluid often if you use your brakes hard. Me, I have never experience brake failure from fluid boil (fingers crossed).
post #9 of 16 Old 07-16-2005, 05:34 PM Thread Starter
avdigigeek's Avatar
Thanks for the info boys.
I think I'm gonna wait on the brake lines
I just got back from getting a custom map done and Fuck its hot !!!!!
Smiley
Sponsors
DCDECALS.net
Hunter S. Thompson.
post #10 of 16 Old 07-16-2005, 07:13 PM
sneaky's Avatar
I run the Motul 5.1 and have not had any probs with it. I have the braided lines also...
I about fell out of my chair when someone said dont worry about brake fluid as it doesnt affect brake fade. Brake fuild is the number one reason you can get brake fade. Once the fuild reached its boiling point then brake fade will be easier to achieve and then add in on that glazed over pads and rotors and it is something that no one want to see when they are grabbing the binders in a hurry.
Change your fluid out at least once a year, you can do it by yourself and it only takes maybe 30 mins to do it. Brake fluid is hydoscopic, meaning at attracts and absorbs water. As it heat cycles the water contaminates the brake fluid causing it to get dark in color. The water in the system then starts corrosion in the system. Bike do not see it as bad as cars, as the cars have more steel products in the brake system than cars.
sneaky is offline
Replacing Brake Lines, Fluid, and Bleeding zx102nv Performance and Tech 20 10-21-2009 05:58 PM
Brake fluid NWZX10 Performance and Tech 6 01-24-2005 03:53 AM
Galfer Brake Lines, EBC HH Pads, Fluid - $130 Shipped. Solo-Moto-Parts Vendors deals 17 01-16-2005 01:40 AM
Replacing Brake Lines, Fluid, and Bleeding zx102nv How To... 1 01-10-2005 03:27 PM
Are you satisfy with the current braking system? Alex31 The ZX-10R 83 12-10-2004 11:06 AM
