Brake Fluid Question - Kawasaki ZX-10R.net
post #1 of 20 Old 08-09-2007, 06:40 PM Thread Starter
mach_man_187's Avatar
Question Brake Fluid Question
We have a discussion going on in our local bike forum as to weather or not sunlight breaks down brake fluid and the real reason why people/race teams use a resevoir cover.....It there any truth to the statement that sunlight breaks down brake fluid????
If you're not living on the edge, your taking up too much space!
mach_man_187 is offline
post #2 of 20 Old 08-09-2007, 09:44 PM
WOODYZX10R's Avatar
i have heard the uv light will but never saw proof, but i do know that if you somehow hurt the master the wristband will stop it from splattering everywhere.
i did a google and found that dot 3,4,5.1 will degrade by sunlight
2004 ZX10R, mostly kinda stock
WOODYZX10R is offline
post #3 of 20 Old 08-10-2007, 12:00 AM
I'm wondering how much 'sunlight' gets through that tupperware bowl on my bike anyways.......
You figure sunblock lotion comes in SPF 50, what SPF do you think a 1mm thick sheet of plastic is?
casey is offline
post #4 of 20 Old 08-10-2007, 07:13 AM
rocketracermike's Avatar
I heard the samething to. Hear in Az. we have a whole lot of sunny days.
rocketracermike is offline
post #5 of 20 Old 08-10-2007, 07:18 AM
bkkninja's Avatar
That cover is just to trap seepage of brake fluid in the unlikely event it does happen. never heard of sunlight effecting brake oil in a plastic cup.
bkkninja is offline
post #6 of 20 Old 08-10-2007, 07:33 AM
brian0128's Avatar
There are 2 main types of brake fluids. Glycol and silicone. Glycol fluids do degrade from sunlight. You usually don't see silicone fluid in bikes...I think it has something to do with a spongy lever feel but I can't say for sure.
brian0128 is offline
post #7 of 20 Old 08-10-2007, 11:19 AM
Big Daddy's Avatar
Images: 38
the #1 killer of brake fluid is moisture due to being hydroscopic, hence it absorbs water from the atmosphere and as it does the boiling level is slowly reduced so all the talk about changing & bleeding fluid IS important.
Big Daddy is offline
post #8 of 20 Old 08-10-2007, 11:22 AM
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
Trust me I changed my fluid out every other race w/e and it needed it. I have seen a fellow racer not change his for a while and then his brakes totally go out on him and he had to quit the race after nearly crashing running straight off a corner. We helped him change it and it was brown and nasty. So while bleeding is a good idea always a complete flush is a good way to keep the fluid fresh.
zx10ragentblack is offline
post #9 of 20 Old 08-10-2007, 11:55 AM
bkkninja's Avatar
Shit and now this. Where my new bottle of brake fluid...
bkkninja is offline
post #10 of 20 Old 08-10-2007, 02:28 PM
Big Daddy's Avatar
Images: 38
Once you crack the seal the process begins so ensuring its resealed tight, stored in a cool dry area is imortant as well.
Brake Fluid? NYC_ZX10 The ZX-10R 13 03-27-2007 12:25 PM
brake fluid vinja314 The ZX-10R 10 12-26-2006 09:35 PM
Brake Fluid? 05Ti10 Performance and Tech 15 08-16-2006 06:18 AM
Dot Brake Fluid. R1GSXRKILLER The Out House 4 04-05-2005 06:11 PM
Brake Fluid?? nolaZX10 The ZX-10R 15 09-08-2004 08:35 PM
