Brake Drag Problems? Solution - Kawasaki ZX-10R.net
 6Likes
  • 3 Post By Brakeman
  • 1 Post By Carlos76
  • 2 Post By Brakeman
post #1 of 4 Old 06-04-2019, 07:52 AM Thread Starter
Hello Troops
A quick heads up here expressly for those who've experienced the progressive deterioration of their brake system typified by poor piston retraction.
Over our many years of working with racing brakes in severe duty conditions, it has become abundantly apparent that the OE aluminum pistons are often the source of this phenomenon which becomes progressively worse over time.
To that end, we've introduced a relatively comprehensive range of ventilated pistons machined from U.S spec stainless steel expressly designed to deal with the the stiction problem present in virtually all modern motorcycle brakes. Granted, racing was the genesis of this development, but the implications extend well beyond racing and into the broader high performance realm of modern sport bikes. At the core, aluminum is a brilliant material with applications in industries that covers an incredibly broad cross-section of manufacturing today...but its use as a brake caliper piston material isn't one of them.
Caliper Racing Pistons
BrakeTech USA is pleased to announce the release our all new Caliper Racing Pistons. Manufactured from proprietary U.S. spec stainless steel to provide much greater thermal stability for Pro level racing. Replaces the highly conductive OE aluminum pistons with specially engineered ventilated design that all but eliminates those thermal transfer shortcoming:
Reduces thermal conductivity by 94%
Dramatically improves piston retraction - reduces brake drag
*Improves brake release for greater control exiting the apex
Virtually eliminates fluid boil
Increases top speed
Available for most late model Sportbikes including M50 and GP4-RX calipers.*
Though not a panacea for all brake problems, this new product category does impact and correct the majority of them. Master-cylinder issues, old/aging piston seals, depleted (contaminated) brake fluid, etc. all play a factor. But thermal dynamics is often the source and these new hi-tech pistons clearly address that shortcoming.
Cheers,
Brakeman
BrakeTech USA*
Brakeman is offline
post #2 of 4 Old 06-05-2019, 09:30 AM
Carlos76's Avatar
I have similar thick wall stainless pistons in my gen4.
Great upgrade, but DLC coated nowdays please.
Secret to drag free wheel is to polish them "inside-out" direction and apply "ATE Brake Piston Grease" at install and cleaning.
Neonmarine likes this.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #3 of 4 Old 06-06-2019, 03:11 AM
or10r's Avatar
This feels a lot like an ad...
or10r is offline
post #4 of 4 Old 06-06-2019, 07:53 AM Thread Starter
Not an ad, but rather a new products press release intended for those either racing or who've experienced problematic piston retraction issues (aka: excessive brake drag).
High tech coatings were considered, however with the caliper seals providing the sole mechanism for pulling the pistons back off the brake pad backplate, a degree of friction is necessary to provide an optimal grip of the piston to perform this vital role. Adding coatings would not substantially improve on this critical function, but would add to cost.
Carlos76 and Neonmarine like this.
Brakeman is offline
