Gen 4: 2011-2015 Brake Bleeding - Issues 2013 ABS - Kawasaki ZX-10R.net
post #1 of 1 Old 06-14-2015, 05:45 PM Thread Starter
aaron403's Avatar
Question Brake Bleeding - Issues 2013 ABS
2013 ABS Model
\When I did my rear sets I had to put a pressure switch in. Bled the rear-brake after the switch was put in and then about a week later they started to feel squishy. Ive read that the brakes seem squishy but I don't remember them being this squishy and requiring the amount of pressure to hold me stopped on a hill. So I went through and started bleeding them again this time with a handheld vacuum pump. About half way through I got distracted and let my cylinder run empty
I've put about 2 liters of brake fluid through the rear brake lines now and I'm still getting air pockets coming out using the vacuum tool. Rear-brake still seems squishy. When I push fluid out with the lever I don't see any air, only with the vacuum tool.
I'm thinking maybe the banjo washers didn't seal properly but I'm sure I would see fluid leaking from the line. If air was getting in somewhere as well I would see fluid else where I would think?
Help please.
aaron403 is offline
Gen 4: Bleeding ABS Icey_Cold The ZX-10R 26 08-19-2017 12:46 PM
Gen 4: Considering buying a 2013 zx10r w/abs Motorcyclemadness The ZX-10R 9 04-16-2015 03:37 PM
Gen 1: Brake Bleeding issues Caffeine Performance and Tech 16 03-11-2014 07:39 AM
2013 White ABS KayiiOmahksstooki Pictures and Videos 20 11-23-2012 01:09 AM
2013 GSX R 1000 and 2013 Hayabusa gets abs URBAN LEGEND General Motorcycle Discussions 53 11-18-2012 02:58 PM
