block off plates - Kawasaki ZX-10R.net
post #1 of 7 Old 01-01-2010, 03:23 AM Thread Starter
block off plates
This mod good or bad for the motor compared to the standard reed valve system?
zx10-06 is offline
post #2 of 7 Old 01-01-2010, 06:16 AM
if the popping on decel is pi**ing you off then fitt the block off plates,as it will stop them completly!!some say it helps throttle feel with block off plates fitted also..and it helps when on a dyno as there's no air going into the exhaust to mess with air/fuel ratio..tis up to you tho,i fitted them and all is well..
krakers10r is offline
post #3 of 7 Old 01-01-2010, 08:18 AM
rppjr's Avatar
rppjr is offline
post #4 of 7 Old 01-01-2010, 09:43 AM
Supercharged Mod
Won't make the slightest bit of difference to the engine itself.
GoFaster is offline
post #5 of 7 Old 01-01-2010, 12:16 PM Thread Starter
Thumbs up
Thanks for the info.I've got block off plates on and after 24 000k's still no problems.Got wondering about the plates when a couple of guys reckon the motor needs the reed valves.I'll rather trust you guys on this one.
zx10-06 is offline
post #6 of 7 Old 01-01-2010, 01:11 PM
tell the couple of guys(mates??)that they are only on bikes to help clean up any unburt fuel left in the exhaust when the throttle is shut...it only sucks air from the air box and shoves it down into exhaust ports,so what else can it do for there engine's??(apart from helping your carbon foot print)..
post #7 of 7 Old 01-04-2010, 12:24 AM
T Double D
Ratfink's Avatar
Images: 9
ive got it on mine and i couldnt tell a big difference at all just cleaned up all the wires and hoses and crap under the airbox lost some weight as well
2005 ZX10r
2009 Monster ZX14 brocked out
2009 SuperStreetBike Magazine Top Speed Challenge Winner ( on a zx10! )
Ratfink is offline
Block off plates spidi511 Performance and Tech 4 06-09-2008 07:57 PM
Block off plates?? vjhils Performance and Tech 6 12-10-2007 08:29 AM
Block-off plates??? 1bad10r Performance and Tech 12 01-06-2007 07:58 PM
Block Off Plates Supraman78 Performance and Tech 21 01-10-2006 03:28 AM
Block off plates Floyd Vendors deals 6 06-10-2005 04:30 PM
