Block Off Plates - Kawasaki ZX-10R.net
post #1 of 16 Old 02-19-2008, 06:42 AM Thread Starter
ninjasuz's Avatar
Question Block Off Plates
Can anyone tell me if they could feel any power increase or power delivery change with Block off plates installed on there 06-07???
ninjasuz is offline
post #2 of 16 Old 02-19-2008, 06:52 AM
axo250's Avatar
Send a message via AIM to axo250
Block off plates only eliminate a bunch of garbage under the air box along with reducing backfire. They will not help you with power at all.
axo250 is offline
post #3 of 16 Old 02-19-2008, 07:04 AM
kmikec's Avatar
on reducing backfire. well worth it
kmikec is offline
post #4 of 16 Old 02-19-2008, 07:51 AM
I've just fitted a set of Ivan's block-off plates, a really comprehensive pack. It does give you more room for working on the plugs, and it saves a bit of messing come dyno time.
doug_uk is offline
post #5 of 16 Old 02-19-2008, 02:07 PM
nite-ryder's Avatar
What he said..... Plus it will make dyno-ing your bike easier..
nite-ryder is offline
post #6 of 16 Old 02-19-2008, 07:43 PM
axo250's Avatar
All this means is the tuner won't have to close a hose up to get your a/f correctly.
axo250 is offline
post #7 of 16 Old 02-20-2008, 10:25 AM
jrbard's Avatar
when u install the plates do you have to plug the holes under the head cover. and what other hoses do u have to plug. pics would be good
jrbard is offline
post #8 of 16 Old 02-20-2008, 10:44 AM
If you look at the picture, the orange pipe cover, bottom left, is all you need, it seals the airbox outlet. Otherwise it's just a case of replacing the stock covers with the Ivans.
doug_uk is offline
post #9 of 16 Old 02-20-2008, 10:47 AM
nite-ryder's Avatar
If all you are doing is adding the block-off plates, then the only hole you need to plug is the bottom of the air-box. That's it. There have been a number of how-to's on this. Do a search and you'll have a number of hits...Some with pics. It's really easy to do, but just time consuming because the allen heads are a bitch to get to and the air-box can be a pain to get off and on....
post #10 of 16 Old 02-20-2008, 11:37 AM
I found the airbox was hard to get off, but surprisingly easy to get back on, some finger muscle is needed to remount the intake rubbers. What annoyed me was the length of the allens, I hope they are holding the cam cover on, cos they are way too long for just for holding a lightweight cover on.
I decided to save some jobs up and do them all at once, so I fitted the Ivans, a rifelman 1/5 throttle insert, a BMC race filter, a speedo healer and a GIPro all in sequence while the tank was off. Once the ice has gone I should have a noticeably different bike to ride
doug_uk is offline
Block off plates?? vjhils Performance and Tech 6 12-10-2007 09:29 AM
Block-off plates??? 1bad10r Performance and Tech 12 01-06-2007 08:58 PM
Block Off Plates Supraman78 Performance and Tech 21 01-10-2006 04:28 AM
block off plates on1whl Vendor Deals 7 09-22-2005 07:37 PM
Block off plates Floyd Vendor Deals 6 06-10-2005 05:30 PM
