bleeding master cylinder - Kawasaki ZX-10R.net
post #1 of 5 Old 08-09-2008, 09:09 PM Thread Starter
joedirt199's Avatar
i read up on how to bleed from the calipers and i have a vacuum bleeder. i tried to bleed my R1 master cylinder the other day and all i think i was doing was pulling the fluid from the lines to the calipers instead of pulling from the resivour. do i squeeze the brake lever while sucking the fluid through then tighten the bleed nipple so that air cant get back in. i can bleed them fine from the calipers but they still dont feel good and tight. i know there is probably air in the m/c i just cant get it back out to the resivour.
Is this where you wanna be when Jesus comes back?
Flags and handlebars should never touch the ground.
GOD made Police so Firemen would have HEROES
MODS: Homemade 1/5 throttle, -1+2 gearing, R1 Master Cyl, Galfer S/B Brake lines, 954 Handlebars, GSXR stock damper, ZX14 mirrors, gutted/shortened/ceramic coated stock exhaust, Hotbodies D/B, Ramair tube brackets, Speedohealer, flush front signals, Fake Sato rearsets, FZ1 Brembo rear master cylinder, Fender eliminated...
joedirt199 is offline
post #2 of 5 Old 08-09-2008, 09:11 PM
ducatiryder89's Avatar
Images: 21
I believe the R1 master is a radial and has a bleeder screw that you must bleed the master first. Once the master has no air the rest is cake.
2005 ZX10R Track Bike With Way To Much Sh*t On It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ducatiryder89 is offline
post #3 of 5 Old 08-09-2008, 09:47 PM
BrandensDogs's Avatar
exactly, bleed the master FIRST until you get lever feel. Then do the lines. Then maybe the master again if it needs it.
BrandensDogs is offline
post #4 of 5 Old 08-09-2008, 10:07 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
Heres what worked for me and a bud of mine..
fill m/c cont with fresh brk fluid..Assumeing yer adding steel braded lines or new calipars even a m/c..Open calipar bleeder screws and wait till fluid flows..Close bleeder screws...Now start pumpin the brk lever 5-10 times and hold to bar,open m/c bleeder screw for a sec,when fluid stops flowin close bleeder screw..Just keep doin that till you get a very firm lever..
Now do the same with each calipar....If after this you have a wimpy feel,go for a short spin and (low traffic area)come back and redo....
craig_sez is offline
post #5 of 5 Old 08-09-2008, 10:27 PM Thread Starter
joedirt199's Avatar
makes sence thanks guys.
Which Master Cylinder ANIKI_THE_EXILED Performance and Tech 8 08-13-2007 05:43 PM
r1 master cylinder norcal10 Performance and Tech 9 05-31-2007 09:19 PM
F/S -5/8 master cylinder - 04/05 10r JBJ Parts, Gear and Accessories 2 02-14-2007 10:28 PM
'05 636 Master Cylinder? zx-10r203 The Out House 1 01-03-2007 05:30 PM
'06 Master Cylinder Older Guy The ZX-10R 7 02-09-2006 09:08 AM
