bleeding front brakes - '04 model - Kawasaki ZX-10R.net
post #1 of 6 Old 04-28-2006, 08:41 AM Thread Starter
JeredH's Avatar
Send a message via MSN to JeredH
i am installing new Galfer lines on the front brakes, and need help.
there is a single brake line coming from the lever & running down to the front right calipur. at the calipur, the line is stacked and a short line runs to the left calipur.
what is the sequential order to bleeding the front left and front right calipur?
JeredH is offline
post #2 of 6 Old 04-28-2006, 08:43 AM
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
dunno, would think right, then left....but havent messed with the stock stuff in a while since i got galfer lines now...wait wait *EDIT* the galfer does not route like that. There are 2 seperate lines from the m/c to the calipers...no crossover with the galfers
zx10ragentblack is offline
post #3 of 6 Old 04-28-2006, 08:45 AM
FuTAnT's Avatar
Images: 7
I'd grab a mityvac and suck from the left, or push from the left, either way. If you do it from the left caliper you'll fill the calier, the line, then the next caliper and up to the m/c. When you're all finished zip tie the brake lever to the bar and leave it overnight, helps to get all of the last air bubbles out.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." Albert Einstein
'85 GSX250S -> '96 ZX6R -> '98 ZX6R -> '00 ZX6R -> '03 CBR954RR -> '04 ZX10R -> '02 ZZR250 -> '06 ZX10R -> '08 KTM 990 ADV
FuTAnT is offline
post #4 of 6 Old 04-28-2006, 09:05 AM
zx-7rking's Avatar
Bleeding brakes you typically bleed the hose that is has the longest distance from the MC first. So that would be the Left Caliper first then the Right, but with these lines I doubt you'd notice a difference with such a short distance of the lines.
BK
05-ZX10R
2K ZX-7R
01' ZX-6R<-- Wifes
zx-7rking is offline
post #5 of 6 Old 04-28-2006, 09:12 AM Thread Starter
JeredH's Avatar
another rider told me this:
right then left...
closest to the master working your way out.
JeredH is offline
post #6 of 6 Old 04-28-2006, 09:27 AM
RickRoush03's Avatar
he said that most likely becasue the stock setup uses that one main line to the right then loops to the left, so if there is fresh fluid bleed from the right, when you do the left, your drawing fresh fluid quicker. if you do it like that, do a quick flush in the right one again. on the galfer or other SS lines, there are 2 lines, one to the left, one to the right.
"Lead, Follow, or get the hell outta my way!!"
Blue 2004 ZX-10R
- 152.5rwhp 77.6rwtq - more than I need
Red 2003 Jack ROUSH Classic #8 of 50
- 375rwhp 381rwtq
RickRoush03 is offline
Brembo Tech Notes - Fluid, Bleeding, etc. CanyonCarver Performance and Tech 3 03-06-2006 09:23 AM
Front end rattle? Possibly brakes? deputydog95 The ZX-10R 5 06-19-2005 06:34 PM
problems bleeding front brakes.... on1whl Performance and Tech 22 04-04-2005 09:45 PM
Squishy front brakes 10 of Spades The ZX-10R 13 05-03-2004 08:53 PM
