Bleeding brakes problem - Kawasaki ZX-10R.net
post #1 of 20 Old 07-28-2007, 07:54 PM Thread Starter
evallarta1's Avatar
I started bleeding my brakes since the fluid in there was NASTY. I bled the front brakes following the manual with no problems. Then I got to the rear brake. Doing the same thing I did with the front I noticed that I was draining fluid but not replacing it from the the reservoir. Well I ended up drained all the fluid from the rear master cylinder and now I get nothing. The line coming from the front of the bike to the rear cylinder is rock hard. But from the rear brake lever to the rear brake is empty. Did I do something wrong? Should I maybe take apart the rear cylinder and and check it? Any ideas?
evallarta1 is offline
post #2 of 20 Old 07-28-2007, 08:07 PM Thread Starter
evallarta1's Avatar
OK after taking a closer look at the manual, is there a reservoir for the rear brake? and if so how the hell do I get to it?
post #3 of 20 Old 07-28-2007, 08:19 PM Thread Starter
evallarta1's Avatar
Nevermind found it.
post #4 of 20 Old 07-28-2007, 08:46 PM
Chickenstrip Eater
SUPER K's Avatar
Send a message via MSN to SUPER K
Duh :iamwithst
http://i117.photobucket.com/albums/o45/josh10r/IMG_0144-1-1-1.jpg
Sent from your mom's IPhone using dirty fingers
SUPER K is offline
post #5 of 20 Old 07-28-2007, 10:26 PM Thread Starter
evallarta1's Avatar
Yeah you actually have to READ the whole section on bleeding the brakes in order to see that there is a reservoir for the rear
post #6 of 20 Old 07-28-2007, 10:35 PM
Chickenstrip Eater
SUPER K's Avatar
It's common sense. This your 1st bike?
SUPER K is offline
post #7 of 20 Old 07-29-2007, 02:06 AM
Larry Grogan's Avatar
Images: 14
evallarta1
We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm
Larry Grogan is offline
post #8 of 20 Old 07-29-2007, 02:09 AM
Images: 14
Just messin with ya bud
post #9 of 20 Old 07-29-2007, 05:04 AM
technic's Avatar
go figure...
technic is offline
post #10 of 20 Old 07-29-2007, 07:48 AM
Chickenstrip Eater
SUPER K's Avatar
We're just bustin yer nuts. It's best to try everything you can think of, when workin on your 10 before postin here or you'll get eatin alive.
SUPER K is offline
Need help with weird brake bleeding problem Lawdog78 Performance and Tech 5 03-30-2007 03:17 PM
06 problem on brakes drofer The ZX-10R 33 06-19-2006 07:04 AM
bleeding front brakes - '04 model JeredH Performance and Tech 5 04-28-2006 09:27 AM
problems bleeding front brakes.... on1whl Performance and Tech 22 04-04-2005 09:45 PM
Bleeding Brakes... HELP!!! nolaZX10 Performance and Tech 11 09-10-2004 12:25 PM
