black oil - Kawasaki ZX-10R.net
post #1 of 10 Old 07-24-2007, 02:35 PM Thread Starter
leemille's Avatar
black oil
i changed the oil and filter in the spring. mobil 1 racing whatever oil. i have done 4 track days, some dyno work and a lot of running in the garage. when i got back from my last track event i looked at the oil sight gauge and couldn't get a reading. so i decided to do an oil change.
the engine is in a race car and i do road course.
the oil was dark black. is this a problem? what could cause it to become so black so quick? any ideas?
"I'm your father, Luke!"
leemille is offline
post #2 of 10 Old 07-24-2007, 03:10 PM
kawaking's Avatar
Send a message via AIM to kawaking
yeah, you waited too long to do an oil change.
06 Lime 10R, street bike
00 Black R6, track bike
kawaking is offline
post #3 of 10 Old 07-24-2007, 03:12 PM
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
Yeah you waited way to long. I change mine after every race or track w/e religiously.
zx10ragentblack is offline
post #4 of 10 Old 07-24-2007, 03:20 PM
FAF
Rent this space
Lot of load on a bike engine when its in a racecar.
FAF is offline
post #5 of 10 Old 07-24-2007, 03:26 PM
Yankee Racer
Images: 9
or in a racebike to But yeah what FAF said.
post #6 of 10 Old 07-24-2007, 04:04 PM
Still here
ZX10Miami's Avatar
Wet clutch rides in same oil that engine uses.
Also if you still have the slipper clutch in there, who knows how much it is slipping when you back off the throttle being that it is in a car. More weight, more contact patch...
ZX10Miami is offline
post #7 of 10 Old 07-24-2007, 04:41 PM
morrisjl2's Avatar
From what I understand, it is not "bad" that your oil is black. That just means it is doing it's job by suspending all of the junk that your engine is producing. However you did wait too long to change your oil. It would be wise, as said above, to change it after every track day.
morrisjl2 is offline
post #8 of 10 Old 07-24-2007, 05:13 PM
10rmotor's Avatar
What was the oil temperature like?
10rmotor is offline
post #9 of 10 Old 07-25-2007, 07:52 AM Thread Starter
leemille's Avatar
oil temp
i don't have an oil temp gauge. but water temp on an 80 degree day was running between 160 and 190. where did you install an oil temp gauge and what gauge and sender unit did you use?
also thanks guys for all the replies and info.
leemille is offline
post #10 of 10 Old 07-25-2007, 05:43 PM
10rmotor's Avatar
I made an adaptor to go in place of the oem heat exchanger (which I found didn't work for crap) that has -8 fittings that feed an oil cooler and external oil filter. In place of the oil filter I have a spin on adaptor with -10 fittings that connects to an inline setrab oil to water heat exchanger. The oil goes through the heat exchanger, then the cooler, and then the filter. I have two sensors, one in the oil filter adaptor (the coolest location), and one in the pan (hottest location) in a bung I welded into it. I can switch between either sensor. I used an autometer gauge with 1/8 NPT sensors.
10rmotor is offline
06 Black...Silver Converted to Black on the AKRAS pics hotstang46 Pictures and Videos 23 09-03-2006 06:19 PM
FS: PAZZO black/black shorty brake lever lavudyar Parts, Gear and Accessories 9 07-07-2006 08:20 PM
Painted F/R Sets Black on Black 10R Ruthless Racing Pictures and Videos 14 10-27-2005 11:42 AM
Black/Black Pazzo Levers Zygoat Parts, Gear and Accessories 8 07-03-2005 04:03 AM
Black on Black - tasty nuts Older Guy Pictures and Videos 13 02-28-2005 09:41 AM
