Gen 1: 2004-2005 a bit jumpy - Kawasaki ZX-10R.net
post #1 of 6 Old 05-21-2012, 10:36 AM Thread Starter
Kawi Demun's Avatar
a bit jumpy
Hello family...looking for some insight. I just did a valve check on my gen 1, and while reassembling the bike i put new plugs in, did the free block off mod, cut the fins in the ram air tubes, cleaned my filter, and the 1/5 throttle insert. Upon the first start up of the bike after 7 days, the idle seems to be a little bit jumpy and slightly lower. I let it run for a few minutes and only got up to 160 degrees f before i shut her off
Now im thinking it may be doing this because i havent taken it around the block yet and put any load on the motor..but i just figured i'd ask before i go out and hurt anything.
thanks in advance
Kawi Demun is offline
post #2 of 6 Old 05-23-2012, 09:12 PM
WhackyWheels's Avatar
im having this exact issue it keeps jumping rpms every few seconds im worried about it.
WhackyWheels is offline
post #3 of 6 Old 05-23-2012, 09:25 PM
BigCat for Prez!
BigCat10R's Avatar
u mean like a lope? mines done that since i put an exhaust on it and its fine
BigCat10R is offline
post #4 of 6 Old 05-24-2012, 04:27 AM Thread Starter
Kawi Demun's Avatar
All is good now lol...I freaked out too soon, just needed to be ran around the block haha..soooo.smooth, just need a good dyno tune now
post #5 of 6 Old 05-24-2012, 05:42 AM
Gen2 Ripper
neverendingmods's Avatar
On my Gen2 I am CONSTANTLY adjusting my idle. It seems to be differnt every time I start bike when temp is different than last time I ran it at all.
My bike seems to be happiest at 1200-1300 rpm setting. Stays smoother and less lopey. If I set it at 1k warm it sounds like it doesn't do a good enough COLD start high idle then. But at around 1300 rpm warm setting the cold start is nice and strong, long, ad smooths out nice when warmed up.
neverendingmods is offline
post #6 of 6 Old 05-24-2012, 10:01 AM
its your spark plugs, the service manual fails to mention that you must screw in the coil plug not push it down. pushing it down strips the threads on the spark plugs.
