Bike won't start... - Kawasaki ZX-10R.net
post #1 of 25 Old 09-02-2008, 12:07 AM Thread Starter
Bike won't start...
I tried to search, but it seems people posted and then never responded back to others helpful insights. Basically, I was on the freeway when my bike literally just went dead. It will not start at all... all it does is make a ticking/rattling noise. What could it be?
stecson is offline
post #2 of 25 Old 09-02-2008, 12:13 AM
mlkx3's Avatar
Check your battery connections
mlkx3 is offline
post #3 of 25 Old 09-02-2008, 12:27 AM
10roller's Avatar
check you fuses?
10roller is offline
post #4 of 25 Old 09-02-2008, 12:30 AM
JUPJON's Avatar
Location: Fargo, ND (only about 6 month riding season unfortunatly)
Images: 15
Need more info, clutch switch problem, kill switch/wiring pinched?
98% of all Harleys ever sold are still on the road. The other 2% made it home.
JUPJON is offline
post #5 of 25 Old 09-02-2008, 12:34 AM Thread Starter
Still working on it... as far as I see everything is hooked up fine. Like I said... I was literally cruising on the freeway when the power went out. the bikes power turns on, but the engine won't start and it just kind of ticks/rattles.
stecson is offline
post #6 of 25 Old 09-02-2008, 01:07 AM
hraponte's Avatar
Had a similar problem with a ZX-7R. Does the egine turn? If it does it could be the ingition switch. Do you hear the fuel pump priming? If not, check the fuel pump.
DB Screen, ASV Levers, PCIII, Yoshimura R-77 Slip-on, Front/Rear Galfer SBK Steel Braided brake lines, Nissin Calipers, Solo Seat Cowl, Fender Eliminator, Integrated tail light, K&N Filter, Anodized red oil/brake caps, Yosh bar ends, modded damper, rim tape, X-TRE, HID light (right side), Aluminum radiator fan, Fork/Frame/Swingarm sliders, 1/5th throttle
hraponte is offline
post #7 of 25 Old 09-02-2008, 01:11 AM Thread Starter
gonna check everything when there is more light out and come back with my findings, keep the suggestions coming!!! and thanks to those who responded already.
stecson is offline
post #8 of 25 Old 09-02-2008, 01:26 AM
tasos's Avatar
Most probably your battery needs recharge/ is dead.
tasos is offline
post #9 of 25 Old 09-02-2008, 08:05 AM
mlkx3's Avatar
, Just hope your stator is not the reason she went dead, just had mine replaced under warranty. Check battery terminal connections. If they are good charge her up and start her, then check voltage at battery
mlkx3 is offline
post #10 of 25 Old 09-02-2008, 08:15 AM
TENN10's Avatar
Images: 145
Do you have a Power Commander hooked up?
TENN10 is offline
bike won't start russell Performance and Tech 12 03-15-2008 10:50 PM
Bike won't start ?? WRECKSHOP General Motorcycle Discussions 1 01-13-2008 12:38 PM
Need Help Bike Won't Start? D on 10R Performance and Tech 16 09-17-2007 03:59 PM
Bike won't start DareDevil The ZX-10R 34 04-22-2006 07:50 PM
Help! Bike won't start! 2ndKawasakiOwner Performance and Tech 10 08-27-2005 04:51 PM
