Bike won't go into gear. Please help. - Kawasaki ZX-10R.net
post #1 of 21 Old 08-30-2010, 01:54 PM Thread Starter
welds like he has palsy
JP636's Avatar
So, I've had my '06 10R sitting in my garage for a little over a year. I start it occasionally to keep the battery going, but it's getting weak. Today I decide to ride it and when I tap it down into first from neutral, it lurches and dies. As if I didn't have the clutch pulled in.
Again, I've done nothing to the bike, but let it sit with the occasional start-up. I tried adjusting the clutch cable, but to no avail. Anyone know what's going on?
JP636 is offline
post #2 of 21 Old 08-30-2010, 01:55 PM
PearlOrange04's Avatar
Clutches prob are shot after sitting that long
PearlOrange04 is offline
post #3 of 21 Old 08-30-2010, 01:59 PM Thread Starter
JP636's Avatar
As in clutch plates? Or cable?
JP636 is offline
post #4 of 21 Old 08-30-2010, 02:52 PM
roby1217's Avatar
you need fresh oil in any case
roby1217 is offline
post #5 of 21 Old 08-30-2010, 03:19 PM
your clutch pack are dry !!!!
you may try to dump some oil on them by adding oil to the engine . The hole to add oil is directly above the clutch pack . Then run the bike until hot and work the clutch leaver many time over with the bike straight up and not on the side stand . I would not force it because you may cause damage to the plates . Let it soak up the oil . Normally when installing a new clutch pack it should be soaked over night in oil >>> i telling you this so you could understand how long it may take for you clutch to soak in the required oil and work . Once it starts to work drive it without ever holding the clutch leaver at stops .
performancezx10r is offline
post #6 of 21 Old 08-30-2010, 03:28 PM
Thank you I really didn't feel like typing all that but to the OP yes what he said
post #7 of 21 Old 08-30-2010, 04:28 PM Thread Starter
JP636's Avatar
Thanks, I'll try that.
JP636 is offline
post #8 of 21 Old 08-31-2010, 12:16 PM
codyc_13's Avatar
Your kickstand is up right? Also what happens when its in first and you try and start it
codyc_13 is offline
post #9 of 21 Old 08-31-2010, 07:08 PM
Adr3naline fix's Avatar
Send a message via AIM to Adr3naline fix
haha this is the first thing that came to my mind.
I doubt your clutch plates are "dry". But I also don't have an idea as to what it would be....so oil away!
Adr3naline fix is offline
post #10 of 21 Old 08-31-2010, 08:59 PM Thread Starter
JP636's Avatar
Yeah, kickstand is up. And if I try to start it in gear, with the clutch pulled in, it lurches and won't start. It's like the clutch isn't even there.
JP636 is offline
Bike stalls when put in gear Vio The ZX-10R 29 08-03-2009 07:10 PM
bike stuck in 3rd gear rayszx10r Performance and Tech 33 04-09-2009 09:13 PM
Need Help...Bike wont rev past 10k...in any gear kneedraggin Performance and Tech 20 12-05-2006 01:05 PM
WTF, Bike is stuck in gear at 741mi mark pmizx10r06 Performance and Tech 36 08-28-2006 04:45 PM
Help: Bike won't start while in gear 10inja Performance and Tech 19 02-22-2005 04:12 AM
