Bike is spitting fuel and FI light has been coming on - Kawasaki ZX-10R.net
post #1 of 5 Old 12-28-2009, 04:30 PM Thread Starter
ssjjhh's Avatar
Will a bad battery cause the bike fuel system to act up and cause the FI light to come on? The bike's battery went dead a couple of times. I have charged it and it has been fine before. But, a couple of months ago I started the bike and let her sit running idle. I noticed the bike was spitting a lot of fuel and it was leaking near where the exhaust pipe and can bolt together. It has never does this before. I put Fuel Injector cleaner in the bike. The FI light was off and I rode the bike around the corner a time or two. It seems to be bogging down and then the FI light came back on momentarily. I am at a loss. The bike was fine and then this problem started.
ssjjhh is offline
post #2 of 5 Old 12-28-2009, 04:55 PM
time for a new battery,Yea they will not run with a low battery.You will not have spark.You will also need to change the plugs.
speeddemon is offline
post #3 of 5 Old 12-28-2009, 11:30 PM
Gen 5 Now!!
08zx10rny's Avatar
you might have a fouled plug or only running on 3 cylinders
GEN 5!!!
08zx10rny is offline
post #4 of 5 Old 12-28-2009, 11:36 PM
ronnulph's Avatar
Send a message via Yahoo to ronnulph
Change it quick. A bad battery can lead to more expensive charging system repairs. I don't know how tolerant a metric bike's charging system is but I seen my harley neighbor go through a stator and two regulators on a weak battery.
08 ZX10
ronnulph is offline
post #5 of 5 Old 12-29-2009, 01:18 PM
When i bought my bike a few months ago i also had an issue with fuel leaking. Tracked it down to the fuel injectors, ended up just being an o-ring. If you get your plastics off, unbolt the tank (leave fuel line connected), and remove the airbox it should be pretty easy to see when you start her up. Hope this helps!
Scott10r is offline
Spitting in the drink red636girl The Funny Pages 3 10-21-2008 10:35 PM
Fuel Light: iskysoma01 The ZX-10R 33 04-09-2007 02:55 PM
Buzz coming from Fuel tank cap while not riding YZF Performance and Tech 16 10-01-2006 03:36 PM
Custom LED Tail Light COMING SOON moose The ZX-10R 43 03-03-2005 09:49 AM
fuel injection light coming on need help rexer'szx The ZX-10R 6 09-23-2004 03:52 AM
