Bike pulling to the right - Kawasaki ZX-10R.net
post #1 of 5 Old 08-23-2012, 01:36 PM Thread Starter
Hi everyone. I am new to the Kawa world. Just got a 2009 ZX 10R and bike is great. The only issue that I have noticed is that this bike tends to pull to the right. Anyone in this forum heard or have experienced something like this. Thanks for any input.
serfloco is offline
post #2 of 5 Old 08-23-2012, 01:42 PM
SkyDork's Avatar
Known issue with the Gen 3. No real solution for it and only speculation what causes it. Search and you can read a lot of different opinions. Kawi claims it the added weight of the muffler off the right side that helps pull the bike in that direction with the crown in the road.
#WordCrimes
SkyDork is offline
post #3 of 5 Old 08-23-2012, 10:18 PM
jakeszx10's Avatar
Check your rear wheel is centered ,mine was not and it pulled to the right. Check that front wheel is centered also, if not loosen fork clamps and bounce up and down and retorque the fasteners.
jakeszx10 is offline
post #4 of 5 Old 08-23-2012, 10:39 PM
Teeks's Avatar
Exactly whats Skydork said. I have had mine apart, have a light aftermarket exhaust, measured, etc, etc, etc. Problem has never gone away. Some people seem to have had it go away or reduced, but I have yet to find a 100% solid answer.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #5 of 5 Old 08-24-2012, 11:15 AM Thread Starter
Thanks for your responses guys. I was also reading another blog where I found that this problem can be caused by a small spacer in the front wheel. I am going to get a shim to see if this can help. Also, I am getting a M4 slip on to reduce the right side weight. I will post as soon I got this done to see what happens.
serfloco is offline
Tags
pulling right, zx 10r
Gen 3: Can not keep Gen 3 from pulling to the right. IggyBcool The ZX-10R 10 06-06-2012 02:36 PM
Bike pulling to the right slmhofy Strip 4 08-01-2011 04:02 PM
'08 pulling to the right ezgoin Performance and Tech 20 02-24-2010 04:37 AM
Please Help-Bike is pulling right???? omoplata The ZX-10R 4 10-15-2008 10:15 PM
Bike on dyno pulling some big numbers toedragger24 Pictures and Videos 9 12-27-2005 12:53 PM
