Gen 2: 2006-2007 Bike cutting out while riding - Kawasaki ZX-10R.net
 4Likes
  • 3 Post By SkyDork
  • 1 Post By BavZ129
post #1 of 5 Old 02-28-2018, 08:09 AM Thread Starter
BavZ129's Avatar
Post Bike cutting out while riding
I've had my 07 ZX 10 for about 2 months now, bought from a dealer. Been having a few issues recently.
Went out for a ride, stopped at a traffic light, the dials went completely of, as I rode off the engine cut out.
First thing I did was change the battery. Bike started up on the first swing, took it out onto the freeway, but i noticed from idle to 3k rpm it splutters and doesn't rev past 8k prm, brought it back home and it couldn't start afterwards.(batt. died)
Took it back to the dealer, he says might have had water mixed in the fuel(not sure how) so he flushed out the tank, checked rectifier, plugs, fuel pump (all seem to be 100%)
According to his mechanic, the brand new Deltec AGM battery I bought was faulty. What you do you guys think? Any input...
BavZ129 is offline
post #2 of 5 Old 03-01-2018, 09:09 AM
SkyDork's Avatar
Welcome to the party!
The first sign that there's a power issue is related to the instrument cluster (not "dials") going dead before the motor dies. That's an indication that the alternator is not provided the needed power and the battery powering the bike. The first thing that happens is the instrument loses power and the motor quits shortly after that since the battery is running total-loss at that point. It won't make any difference if you charge the battery again and restart it because it won't last long. This cycle gane damage the battery. The Gen 1 and 2 have a history of the alternators going out. Since the alternator consists of the rotor and stator, the stator is what goes bad. In your case, charge the battery, replace the stator, and see what you get.
The other possible point of failure is the rectifier. The purpose of that is to convert the variable AC voltage to a constant 12v DC. If that fails, no power gets to the battery to keep it charged. Check both if you can, but it's more than likely the stator that's bad.
evilaugust, lun471k and BavZ129 like this.
#WordCrimes
SkyDork is offline
post #3 of 5 Old 03-01-2018, 09:34 AM
The Prophet's Avatar
Good work Skydork, at least he could buy you a beer.
The Prophet is offline
post #4 of 5 Old 03-01-2018, 12:28 PM
evilaugust's Avatar
What @SkyDork said. Out of curiosity, how many miles on the bike? I just replaced my Gen2 stator at 12k. Thing was cooked.
evilaugust is offline
post #5 of 5 Old 03-05-2018, 12:06 AM Thread Starter
BavZ129's Avatar
Hi Guys
@ Skydork... I do owe you a beer! You were 100% right. I got the bike back from the dealer and he advised I need to replace the battery, AGAIN. (btw Deltec load tested the battery & all was fine)
As a client of his, I was very disappointed at his lack of after service, anyways screw him....
Downloaded the service manual of the forum and used Skydorks advise as a guide. First thing I did was drain fuel tank(in case of bad fuel), changed plugs & oil, tested rectifier and stator...
Stator was fine, but the rectifier was faulty... Replaced with a new one.
After a full charge on my "faulty" battery and fresh fuel, bike is running very smooth throughout revs, no splatter and battery is getting sufficient charge.
@evilaugust... Im from South Africa so my odo reads in km, its now just over 36000km (roughly 22000 miles).. It's a old boy, but runs like a beast.
Thanks for all the info. guys, really appreciate it.
lun471k likes this.
BavZ129 is offline
Tags
battery, gen2, rectifier, zx10
help bike cutting out one release of clutch streetfighter The ZX-10R 2 06-28-2015 02:15 PM
Gen 4: QS cutting and bike shutting off dudewhrsmybike The ZX-10R 28 12-26-2014 04:02 PM
Gen 4: Help! bike is Cutting out superx2 The ZX-10R 14 08-24-2013 03:02 PM
Bike keeps cutting out MisterD The ZX-10R 1 12-07-2012 05:28 PM
bike cutting off? HELP tone.r Performance and Tech 0 04-12-2009 04:25 PM
