Bike cuts out at high rpm - Kawasaki ZX-10R.net
post #1 of 9 Old 11-07-2008, 03:12 AM Thread Starter
07ZX10RJoe's Avatar
I have an 07 ZX10, The only performance mods are my Two brothers Single side exhaust. It does it at all temps outside, and if the bike is warm or hot. I pulled the tre off thinking that was causing it, didn't fix it. Changed the spark plugs and that didn't change it either. At high rpm around 11k the bike will cut out as if someone is turning the key off and on. I can't seem to figure out what it is. Oh, I also checked the tilt sensor and the kickstand switch and it still does it. Any help is greatly appreciated.
07ZX10RJoe is offline
post #2 of 9 Old 11-11-2008, 11:48 PM
If your sure your not bounceing off the rev limiter, the fuel pump would be my suggestion. That is just a suggestion, don't run out and buy a new one till someone confirms.
10man04 is offline
post #3 of 9 Old 11-12-2008, 01:30 AM Thread Starter
07ZX10RJoe's Avatar
Yeah I'm sure its not bouncing off the limiter cause it sometimes struggles to get there. If it does get there its a slow bounce. The bike is down on power so I've got it in the shop waiting for a day to pull the take off and check the filter and also the vent tube. Hopefully I'll find an answer then.
post #4 of 9 Old 11-12-2008, 01:44 AM
Gen2 Ripper
neverendingmods's Avatar
Make sure you don't have a blockage in the tank sender(pet cock). Sounds like fuel starvation/lean condition. What did your plugs look like. Were they white? Light tan is what you want.
Compression test/leakdown.
neverendingmods is offline
post #5 of 9 Old 11-12-2008, 01:58 AM Thread Starter
07ZX10RJoe's Avatar
The plugs looked normal, more of a tan coloration no white to them. I gapped them and then replaced them and still no change. Hopefully its just something with the fuel filter.
post #6 of 9 Old 11-12-2008, 09:14 AM
Supercharged Mod
Fuel pump ...
The only fuel filter is the inlet "bag" on the intake of the fuel pump inside the tank.
GoFaster is offline
post #7 of 9 Old 11-12-2008, 09:23 AM
WRECKSHOP's Avatar
Either a fueling issue or a coils going badd.....
WRECKSHOP is offline
post #8 of 9 Old 11-13-2008, 05:50 AM
timjw_82's Avatar
Originally Posted by GoFaster View Post
Fuel pump ...
Usually is... same problem on my 04... fuel pump!
timjw_82 is offline
post #9 of 9 Old 11-13-2008, 08:31 PM
Dragone's Avatar
Images: 11
yeah, was thinking fuel pump/filter or lack of charge to cause a high rpm flutter.
W.F.O.ing with style will bring life back into focus
Dragone is offline
Help!! Bike cuts off when I shift to first deidreant The ZX-10R 23 11-17-2008 08:22 PM
Engine cuts off at 6,000 RPM Jay10282 Performance and Tech 14 09-11-2007 05:19 PM
My bike idles too high.... 1bad10r Performance and Tech 17 05-07-2007 11:52 AM
FS. Titanium Mountain Bike (high end) valskater Garage Sale 6 11-13-2005 12:06 PM
Shogun No Cuts barryblanken The ZX-10R 3 09-07-2005 10:45 AM
