Big problem 10r only 105 horsepower - Kawasaki ZX-10R.net
post #1 of 25 Old 04-04-2013, 05:26 PM Thread Starter
Ok i new my 06 zx-10r was running slow but no problems besides that. So ive gotten it put on a dyno they tried to tune the bazzaz. Only was at 91 horsepower, they removed the bazzaz & put a powercommander 3 on and got it tuning up to 105 horse, and then it stopped. Sooo im missing 60 horses somewhere ? Only ideas i have are sensors or cat converter clogged ? But dont think that would cause so much loss...please help
SKREW is offline
post #2 of 25 Old 04-04-2013, 06:42 PM
Supercharged Mod
What's the maintenance history like? Air filter? Fuel pump?
GoFaster is offline
post #3 of 25 Old 04-04-2013, 07:00 PM
Slow Poke
bgmagma10's Avatar
Wow! Is it runnin on 3 cylinders? Does it sound right?
bgmagma10 is offline
post #4 of 25 Old 04-04-2013, 07:07 PM
Check cylinder compression, check your spark plugs and air filter.. Im baffled as to how thats even possible..
sckrocodile is offline
post #5 of 25 Old 04-04-2013, 07:12 PM
SpazOnaZX's Avatar
Does it say ZX-6R on the tail fairing? :)
Seriously though, does it rev like it has a fuel pump issue or an exhaust back pressure issue?
SpazOnaZX is offline
post #6 of 25 Old 04-04-2013, 07:20 PM
Post Whore
-Op-'s Avatar
Sidestand switch? Does it rev all the way to redline? Spark plugs, air filter, bad fuel pump.
-Op- is offline
post #7 of 25 Old 04-04-2013, 07:24 PM
thundercoupe9's Avatar
does the engine say gsxr on it?
thundercoupe9 is offline
post #8 of 25 Old 04-04-2013, 07:42 PM
can you post a video of the bike running? It might help to diagnose the problem in trying to figure out where half of your power went.
post #9 of 25 Old 04-04-2013, 07:51 PM
badassjake's Avatar
leakdown check on all 4 cylinders.....then go from there, that will tell you a story and a direction you need to continue in.
badassjake is offline
post #10 of 25 Old 04-04-2013, 08:03 PM
what kind of a dyno it was? And I still don't get how pc3 can get 15 more hp over bazzaz................are you sure they weren't pulling your chain?
ZX6R Service Code 51 Problem Big Problem sysroot The ZX-10R 0 10-26-2012 01:30 PM
Gen 2: BIG PROBLEM Help ASAP Please Solo-Six Performance and Tech 28 07-18-2011 07:09 AM
FS: Nikon D70 w/2 AF Nikkor's 28-105 & 70-300 Ca Pete Garage Sale 3 03-27-2011 10:56 AM
big problem need help!!! RDLYN13000 Performance and Tech 20 07-14-2009 04:49 PM
big problem Funaru Performance and Tech 11 06-15-2006 02:19 AM
