Which is better MC or Calipers? - Kawasaki ZX-10R.net
post #1 of 14 Old 12-29-2008, 08:11 AM Thread Starter
ZX10man's Avatar
I know that these have been discussed ad nauseum separately, but I couln't find this specific answer. If only one brake mod was going to be done on a Gen I, which is better: change the calipers to the ZX-14 / ZX-6R or change to a radial master cylinder?
ZX10man is offline
post #2 of 14 Old 12-29-2008, 08:33 AM
Postwhore with an 04
bcm0018's Avatar
No one has done this testing specifically. I think goldfish was going to but hasen't yet. If you were only doing one I thik the calibers might be the better way to go here. I have just the calibers but haven't insalled them because I want to do lines and a MC at the same time.
Also if you get a used set of calibers and don't want to keep them for some reason so you can get a MC you should be able to sell them for almost what you paid.
bcm0018 is offline
post #3 of 14 Old 12-29-2008, 08:34 AM
jcw
Are you doing trackdays?
I think the stock calipers properly bled with good brake fluid and in good shape are perfectly fine for the streets. They tend to fade at the track, though. But that's with pretty aggresive use.
Just my impression.
Steel braided brake lines may be better first mod if not done already.
BTW, I have the radial MC but stock calipers. I have a set of Nissin calipers on the shelf but haven't needed to change until the next trackday.
jcw is offline
post #4 of 14 Old 12-29-2008, 09:17 AM
ZX-10R_04's Avatar
If you change to zx14 brakes you will be happy as & thats the best option
Bmc filter, Hels Braided Brake lines, Nissin ZX14 Calipers, Brembo, RCS19 M/C, Ohlins damper,Fender Eliminator, Puig screen, Smoke Integrated taillight, Green front indicator lens's, Mirror block plates, Gauge Mod, Vortex rear sets, Personalized # Plate, Pazzo levers, 1/5th Throttle insert, H.I.D Headlights 5000k, Seat cowl, Gen 3 Swingarm, Titanium exhaust hanger , Racefit Growler ,GIpro TRE , Michelin pilot pures, -1 front sprocket, PCIII, SpeedoHealer v4, Factory Pro V Stacks
ZX-10R_04 is offline
post #5 of 14 Old 12-29-2008, 09:49 AM
kawiralph's Avatar
Change the calipers (CBR 1000RR, ZX14/6 Nissin, 4-pot R1). Changing the MC only masks the problem of the OEM Tokico calipers. The OEM MC is fairly small (only 14 mm) so changing to the OEM radial MC (16 mm) will make a difference just due to the fact that you "move" more brake fluid given the same lever travel.
I'm using 4-pot R1 calipers with the OEM MC and its like night and day.
I already suggested this about 2 years ago, but thats another story....
Only green is really mean! 1984 GPZ 900R & 2004 ZX10R => 20 years of NINJA power
kawiralph is offline
post #6 of 14 Old 12-29-2008, 11:02 AM
goldfish's Avatar
Well I just got done installing the zx6r radial master on mine, already had the calipers from a cbr and just with what I have felt as of yet, the calipers were in my opinion the best bang for the buck. with just swapping calipers first the brakes were ten times better and really good, but you still have a lot of take up before they really engage due to the non-radial MC, so I swapped that out and now mine is on par/better then the 08's, IMO. but the comparison is coming as summer gets closer.
I never gave it to anyone that didn't deserve it...
goldfish is offline
post #7 of 14 Old 12-29-2008, 11:25 AM
Gang Green's Avatar
My vote is for calipers first. The difference for me was huge. Better bite and feedback. I have a handful of braking now instead of a fingerfull.
Rubber Side Down!!!
"Read The Signs"
God gave Rock'N Rolll to ya, and Kawasaki too!
Gang Green is offline
post #8 of 14 Old 12-29-2008, 06:56 PM Thread Starter
ZX10man's Avatar
Thanks for the replies, I have a better idea on what to spend my Christmas money on now.
ZX10man is offline
post #9 of 14 Old 12-29-2008, 08:02 PM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
Do the MC first.
THere more members here that changed their MC's and are happy with them without changing the calipers. There are track-addicts in here too who never changed their calipers and are happy with them.
I say change your MC first, the lines.. if its not enough, change the calipers.
Lucky10R is offline
post #10 of 14 Old 12-29-2008, 09:31 PM
sweetride10r's Avatar
1000rr calipers all day long love mine made a huge diff over just the master
bike is down for not but not out
turbo project is a slow go no money
Need some work done
call 586-214-2414
sweetride10r is offline
The cbr calipers MisterD The ZX-10R 105 08-30-2010 09:43 AM
???? 08 calipers fit 05 streetfighter Performance and Tech 7 12-04-2008 12:28 PM
About the CBR Calipers... MisterD General Motorcycle Discussions 4 10-28-2008 03:03 PM
ISR calipers evan_880 Performance and Tech 0 07-28-2008 09:31 PM
calipers Redneck Rocket Performance and Tech 3 12-20-2007 11:42 AM
