Best way to mount a degree wheel? - Kawasaki ZX-10R.net
post #1 of 14 Old 07-17-2005, 03:28 PM Thread Starter
For thise who have degreed thier cams what is the best way or method for mount the degree wheel to the crank?
ZX ZBest is offline
post #2 of 14 Old 07-17-2005, 04:07 PM
busaforhire's Avatar
however you can best get it on there without obstruction. the last bike I did cams on was a Busa and I attached it from the stator side.
05 lime green. Sato slip-on, pc3usb, bmc race filter.
"when ya lose site of why ya ride then you've lost what really matters"---THE MOTORHEAD
busaforhire is offline
post #3 of 14 Old 07-17-2005, 06:51 PM
Bobster's Avatar
Send a message via AIM to Bobster Send a message via Yahoo to Bobster
With the engine removed, we mounted to the oposite end of cam gears.
Bobster is offline
post #4 of 14 Old 07-17-2005, 08:38 PM Thread Starter
Not exactly clear on what you mean here Bob. I got the engine out and the only place the wheel might go is on the crank or I'll have to open up the other side of the engine and see what is available there.
ZX ZBest is offline
post #5 of 14 Old 07-17-2005, 11:17 PM
Bobster's Avatar
We mounted it on the crank, opposite end of the cam gears, chain side. And turned the crank for adjustments, turning the crank with a wrench from the cam chain side of engine. Theres obviously only 2 ends of the crank. 1 side for wheel and other side to turn for making adjustments.
Bobster is offline
post #6 of 14 Old 07-17-2005, 11:32 PM
left side of motor as you are sitting on bike.
post #7 of 14 Old 07-17-2005, 11:34 PM
Bobster's Avatar
exactly, maybe i shouldve just said that.
Bobster is offline
post #8 of 14 Old 07-17-2005, 11:46 PM
Big Daddy's Avatar
Images: 38
duh.
Big Daddy is offline
post #9 of 14 Old 07-18-2005, 04:45 PM Thread Starter
I follow you now! If I can only figure out how or where all the tappet shims should go being they all fell out, then I can get started on degreeing. Not that anyone else is as stupid as me but do not turn your head upside down once off. Things fall out!
ZX ZBest is offline
post #10 of 14 Old 07-18-2005, 05:01 PM
yea you learned your lesson there didn't you... your in for a tedious task then..
I had a head i bought from someone with NO shims installed and heres what I did..
I took the smallest shims and used those as a baseline for measurement.
then I laid out what I had and tried to figure out what would work best with what I had..
you may find that you need some different sized shims and I was able to swap some out with the local dealer so that I could get all my valves in spec.
take your time on the shims though because you don't want to make a mistake and end up doing it all over again.
Ohlins Side Mount Steering Damper zx7marsh The ZX-10R 18 05-05-2005 10:58 AM
Gasket and Cam Install BNninja How To... 42 04-08-2005 09:55 AM
Warning About BST Carbon Fiber Wheels........ SP8 The ZX-10R 20 01-18-2005 08:28 AM
Tech Talk: RADIAL MOUNT CALIPERS flatout Performance and Tech 6 11-04-2004 05:48 AM
To High mount or not to High mount BNninja Performance and Tech 4 10-25-2004 01:59 AM
