Best way to clean a rashed engine cover engine? - Kawasaki ZX-10R.net
post #1 of 5 Old 06-06-2007, 01:46 AM Thread Starter
BANNED
Exclamation Best way to clean a rashed engine cover engine?
I just pulled off my left engine cover on my 0510R and I have pebbles in there, grass and just a bunch of crap. what the hell should I do to clean it out? Any suggestions will help!
Suzuk1ki11a is offline
post #2 of 5 Old 06-06-2007, 12:56 PM Thread Starter
BANNED
I know someone has experienced this......c'mon guys I need some secrets.
post #3 of 5 Old 06-06-2007, 01:10 PM
MIA Ex-Mod
Tread70's Avatar
Take off the clutch cover, oil pan, oil cooler, oil filter. Flush the motor with something like mineral spirits or something similar to that. A parts washer is a good thing to have to clean these things and you can use the fluid they have in them to flush the motor out.
Clean the oil pan and visually inspect the oil screen in the oil pan and rinse it out good. Pull the clutch out and clean and soak them in some oil. Remove the oil cooler and using the parts washer set it so it runs the fluid through the oil cooler to get it cleaned out, then blow it out with some air, tie wrap the handle down on the air blower from a compressor and set it up to blow in the cleaned oil cooler, say 5-10 mins.
After putting everything back together, fresh oil and filter, crank it up and let it idle for about 15 mins, shut it down let it cool and change the filter and oil again. It wouldn't hurt to do this at least 2-3 times; buy the cheap filters for this. Last oil and filter use what you would normally use, and put everything back together like new or used plastics and stuff and ride.
Tread70 is offline
post #4 of 5 Old 06-06-2007, 01:21 PM Thread Starter
BANNED
Thanks that sounds like a good technique and that should about cover everything and keep me from having a spun bearing down the road.
post #5 of 5 Old 06-06-2007, 01:38 PM
zx-7rking's Avatar
I got your Email, And I was writing up a repsonse. But Tread70 covered just about everything I was gonna say. Except After starting it back up with fresh oil and filter let it run, drain and then drop the Oil pan again..PITA I know check the oil screen, and the bottom of the oil pan, if they are clean after the first run. New oil and filter, and you should be good to go.
BK
05-ZX10R
2K ZX-7R
01' ZX-6R<-- Wifes
zx-7rking is offline
WTB left side engine cover 04/05 zx10 nelly250 Wanted: Buy or Trade 2 06-01-2007 06:12 PM
Clean the engine with Sea Foam? hotstang46 The ZX-10R 12 05-14-2007 12:17 AM
Engine cover? majtii The ZX-10R 30 08-20-2005 05:32 PM
Need a new stator engine cover? RickRoush03 The ZX-10R 1 07-22-2005 11:08 AM
engine cover bolts... 10roller Performance and Tech 4 07-18-2005 07:06 PM
