Best 90 Degree Valve Stems? - Kawasaki ZX-10R.net
post #1 of 24 Old 09-02-2014, 01:24 PM Thread Starter
STEALTH-FIGHTER's Avatar
Looking for a quality set for some aftermarket wheels. Looks are great, but functionality is most important. Don't wanna have to worry about them leaking.
I have seen a couple that look pretty good. SportbikeTrackGear sells these for around $30. They use a lock nut to stay secured.
Attachment 284690
Bikemaster also makes a similar set for about $20
Any experiences with these, or recommendations on better ones?
What is best in life?..
TO CRUSH YOUR ENEMIES, TO SEE THEM DRIVEN BEFORE YOU, AND TO HEAR THE LAMENTATIONS OF THEIR WOMEN.
STEALTH-FIGHTER is offline
post #2 of 24 Old 09-02-2014, 01:43 PM
SkyDork's Avatar
Those are actually 83 deg valve stems.
I got mine from here. They're all pretty much the same thing.
http://www.kurveygirl.com/shop/produ...roducts_id=142
#WordCrimes
SkyDork is offline
post #3 of 24 Old 09-02-2014, 01:59 PM Thread Starter
Thanks SkyDork. I'll check them out. I know some have a plastic base vs all aluminum. Just want to make sure I get the right ones the first time around.
Here are the Ariete's from SBTG. First pic didn't post correctly.
post #4 of 24 Old 09-02-2014, 02:07 PM
SkyDork's Avatar
The Arietes are pretty popular as well. They're all aluminum and I used a set of those on my old bike. You shouldn't have any issues with them if you go that route. I wouldn't want any plastic ones, that's for sure.
#WordCrimes
SkyDork is offline
post #5 of 24 Old 09-02-2014, 02:12 PM
SkyDork's Avatar
The Bridgeports come in blue to match your new CZs though.
http://www.kurveygirl.com/shop/produ...roducts_id=674
#WordCrimes
SkyDork is offline
post #6 of 24 Old 09-02-2014, 04:51 PM Thread Starter
It's funny, the only Ariete's still in stock at SBTG are the blue ones
Do you think there is any quality difference between the two?
post #7 of 24 Old 09-02-2014, 05:18 PM
Omgnqqb's Avatar
Just curious, what's the lifetime of these angled valve stems? Or how often do you guys replace them (if any)?
Omgnqqb is offline
post #8 of 24 Old 09-02-2014, 05:55 PM
SkyDork's Avatar
No differences that I would expect. I'm sure they're the same thing.
You don't replace them like the rubber ones. Once installed, you leave them alone. The valve cores are replaceable just like any valve stems if there's any leak issues. But the valve body is permanent.
#WordCrimes
SkyDork is offline
post #9 of 24 Old 09-02-2014, 06:23 PM
Omgnqqb's Avatar
copy that. ty sir.
Omgnqqb is offline
post #10 of 24 Old 09-02-2014, 08:39 PM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
I have a set of blue ones at my shop.. And had a few other colored ones as well the anodizing is shitty but the valve is good I use ariete, never any issue and they should come with these stock!
I would get silver to be safe or you may need me to coat them for you lol
www.sportbikepc.com
Sport Bike Powder Coating,LLC
06blackpearl is offline
FS>83 degree valve stems..... 06blackpearl Parts, Gear and Accessories 8 03-19-2011 07:56 AM
need Valve stems ZX10Rracer Vendors deals 1 04-13-2009 09:28 AM
Need Valve stems ZX10Rracer Wanted: Buy or Trade 0 04-12-2009 12:31 AM
How do you remove rubber valve stems? Ninjamaster General Motorcycle Discussions 21 06-10-2008 12:32 AM
Anyone use the 90 degree valve stems? brian0128 The ZX-10R 8 02-28-2007 11:48 PM
