Bent forks? - Kawasaki ZX-10R.net
post #1 of 9 Old 10-22-2010, 03:11 PM Thread Starter
Bent forks?
So i finally did it, after believing that i was immune . Dropped the bike @ about 10 mph leaving work on a cold night. Just lost the rear. Bike came out suprisingly well, better than my bruised up leg, lol. Well took her out for a test ride last weekend and realized that although she is tracking straight, the handlebars/top triple clamp are not straight while i'm heading straight. Is this most likely a case of the forks twisting in the triple tree or bent forks. Thanks for all input!
Scott10r is offline
post #2 of 9 Old 10-22-2010, 03:16 PM
Quick10's Avatar
At that speed most likely just twisted in the clamps
Quick10 is offline
post #3 of 9 Old 10-22-2010, 03:18 PM Thread Starter
Thats what i was thinking as well. Gonna take it to the local shop and get the once over for peice of mind i think.
Scott10r is offline
post #4 of 9 Old 10-22-2010, 03:29 PM
Quick10's Avatar
I would definitely do that and get them to align it for you.
Quick10 is offline
post #5 of 9 Old 10-22-2010, 03:40 PM
NinjeR's Avatar
Man, and I just sent you a mid fairing too!
I'm with quick, just probably twisted the clamps.
NinjeR is offline
post #6 of 9 Old 10-22-2010, 05:18 PM Thread Starter
Luckly its safe in the closet lol. Ive been riding w/only front fairings.
Scott10r is offline
post #7 of 9 Old 10-23-2010, 09:47 AM
2ligitninjas's Avatar
If you have a front stand you can fix it. Just loosen the upper and lower tree then you can twist everything back straight. If you want to check the forks this would be the time. Take a wheel balancer and place the fork on it and spin, But you gotta have a front stand that goes under the head.
2ligitninjas is offline
post #8 of 9 Old 10-23-2010, 11:44 AM Thread Starter
Thanks man, i'm gonna give this a shot before i take it to the shop. Probably saved me a few bucks .
Scott10r is offline
post #9 of 9 Old 10-23-2010, 12:17 PM
You need to loosen the front axle as well, and the top triple nut if possible along with all of the fork/triple pinch bolts. I loosen the lower pinch bolts and snug them up slightly enough to just hold the forks in place, stradle the front wheel between your legs (fender removed), and twist the bars back and forth until you find the center. Be sure to twist it back and forth a few times to remove all tension. You'll be back on the road in no time.
Cocky Rooster is offline
Ohlins Road&Track forks VS Superbike forks? JLG0987 Performance and Tech 2 01-05-2010 10:42 PM
Bent rim sladkixxx The ZX-10R 22 05-07-2009 03:24 PM
bent rim reckless1 The ZX-10R 4 08-28-2005 01:36 PM
Got BENT !!!???? rdandy5875 The ZX-10R 15 03-27-2005 10:20 AM
Does anyone know if the front forks can be swapped with forks from another model liljunglist2 The ZX-10R 2 02-04-2005 02:39 PM
