Bazaar quick shifter mounting problem - Kawasaki ZX-10R.net
post #1 of 7 Old 01-03-2015, 01:34 PM Thread Starter
I am putting on a Bazzaz QS4 stand alone quick shifter onto my 2011 ZX10R and I ran into some mounting issues. The lead for the sensitivity adjustor is very short. So finding a place to mount it where it is accessible is very difficult. I was gonna mount it under the tank but then Its hard to get to it for any adjustment. Unless its a set it and forget it thing in which case it wouldn't matter where it was, I might be able to squeeze it in above the countershaft sprocket since I will be having the cover off. Im just not sure how delicate this thing is to being exposed to elements like that (wind, moisture, dirt, etc). Anyone put one of the these on your bikes?
mokulea is offline
post #2 of 7 Old 01-03-2015, 01:47 PM
Crash Test Dummy
Hernando's Avatar
Send a message via Yahoo to Hernando Send a message via Skype™ to Hernando
I'm not understanding this. I've had The QS4 on many bikes and never had a problem locating the device anywhere that I wanted to. Maybe I'm thinking of the wrong component.
But the hub itself (the box that has a mini USB port for adjustments) isn't something I'd leave exposed to the elements.
Bear Jew
Hernando is offline
post #3 of 7 Old 01-03-2015, 01:49 PM
Crash Test Dummy
Hernando's Avatar
Oh I think your talking about the lead from the pressure switch I'd mount it under the tank.
Bear Jew
Hernando is offline
post #4 of 7 Old 01-03-2015, 06:09 PM
The new strain gauge sensor has two leads, one lead controls the sensor sensitivity and the other connects into the harness. I've been looking at where to mount that as well. I may tune the qs on my buddies dyno and then just leave it under the seat.
J_fuggin_t is offline
post #5 of 7 Old 01-03-2015, 11:53 PM
Jstamm33's Avatar
I just put a qs4 on my '11, it was relatively easy finding a place to mount the mini hub for sensitivity adjustment. I just put it underneath the seat, wherever it's clean and won't bounce around. Your qs4 should have come with some Velcro, it works great.
Jstamm33 is offline
post #6 of 7 Old 01-04-2015, 12:43 AM Thread Starter
Yes its the sensitivity adjuster. So it sounds like once its adjusted properly you rarely touch it again so it doesn't matter where you put it. I will mount it under the seat then. Thanks for the info.
mokulea is offline
post #7 of 7 Old 01-04-2015, 12:46 AM Thread Starter
or under the tank
mokulea is offline
Lanyard mounting problem JLG0987 Strip 17 05-29-2012 07:11 AM
the difference between an Air shifter and Quick shifter Dam Fool 3000 The ZX-10R 34 10-14-2010 11:22 AM
Air shifter bottle mounting ideas! ! cbolton69 Strip 3 03-27-2010 10:19 AM
mounting air shifter tone.r Performance and Tech 4 12-08-2007 08:45 PM
Problem with Dynojet Quick Shifter - help please 05kaw10r The Out House 0 11-12-2005 06:12 PM
