battery problems - Kawasaki ZX-10R.net
post #1 of 6 Old 12-10-2008, 08:02 PM Thread Starter
slav's Avatar
Send a message via AIM to slav
Exclamation battery problems
Bought a megaboost battery from cycle gear and have had nothing but problems. After 40k miles I felt my stock battery getting a little weak, so I bought the megaboost... they charged it for a couple hours before I picked it up. put it in the next day... and nothing. I had to push start. ended up running it for a good 2-4 weeks before my bike sat for about 2-3weeks. Tried to turn it on and nothing. Took it to them, charged it till it said 100%. Put it in my bike yesterday, ran it to work, to school, and then back home tonight. Stopped to talk with the security guard so he can see my bike (will post pictures this week... hint phrase: all carbon). I left the bike on as we talked for a little, shut it off, then turned the key so he can see my tail light on without the bike working for less then a minute... get on to turn it on and go home.... you guessed it... could not turn on. anyone have ideas?
slav is offline
post #2 of 6 Old 12-10-2008, 08:03 PM Thread Starter
slav's Avatar
I do need to change spark plugs... not sure if that helps.
slav is offline
post #3 of 6 Old 12-11-2008, 11:30 AM Thread Starter
slav's Avatar
Nothing?!
slav is offline
post #4 of 6 Old 12-11-2008, 11:49 AM
10R_Havens's Avatar
By not turn on, do you mean it will not even crank or it will not catch and fire up?
10R_Havens is offline
post #5 of 6 Old 12-11-2008, 02:18 PM Thread Starter
slav's Avatar
fire up... makes the dead battery noise. Anyone know what battery I'm talking about? maybe heard feedback?
slav is offline
post #6 of 6 Old 12-12-2008, 01:04 AM
Daves Cycles's Avatar
Check your charging system first by removing the seat to access battery.Make sure the battery is good by doing a load test on it before you do this test;
Start your bike up and let it run at idle.Connect a digital volt meter to the battery.You should have around 12 volts at idle.Now throttle the bike up to 3 or 4 thousand RPM.You should now read around 14 volts.If it does,charging system is good.If it doesn't it's bad.
So if you load test the battery and it's good.Test the charging system and it's good the only thing left is a draw(short).
If that's the case.With the key off, take the negative lead off the battery.Connect a digital amp meter between the negative lead and the negative post on the battery.You shouldn't have much over 1.5 amp draw.
Granted I don't know if you have a Digital meter or know how to operate it.But you asked.Hope this helps you out.PM me if you need more info.
05 green ZX10R,Akrappovic Evo 2 Carbon w/ hex shorty can full exhaust system,Power Commander USB,Radial front master cylinder(636),Goodridge front and rear carboline brake lines,07 CBR1000RR front brake calipers,Vesrah race front brake pads,Targa tail kit,flush mount front signals,Cabon fiber led rear signals,Ohlins steering dampers,-1 front,Speedo Healer, Pilot Power tires,Gipro Tre and gold Sato's rearsets.
Daves Cycles is offline
How do you get the Battery out?? guzzi71 Performance and Tech 6 11-30-2008 04:22 PM
battery beau23024 Performance and Tech 2 09-02-2008 08:04 AM
Battery special k Performance and Tech 1 06-17-2008 12:08 AM
need ZX-10 battery madnessracing Wanted: Buy or Trade 3 10-01-2007 05:35 PM
Take out my battery solarbeast06 The ZX-10R 14 02-06-2007 06:10 PM
