Bar Ends - Kawasaki ZX-10R.net
post #1 of 12 Old 01-01-2009, 06:31 PM Thread Starter
KDT4's Avatar
Send a message via AIM to KDT4 Send a message via Yahoo to KDT4
Bar Ends
I have an 08 10 and was wondering, How do you change out grips? I cannot get the bar ends off to replace the grips! My main ? is how do i remove the bar ends? Thanks
KDT4
KDT4 is offline
post #2 of 12 Old 01-01-2009, 06:54 PM
Speed Freak
garth285's Avatar
I think its either a 8 or 10mm allen that you need to unscrew the bar ends.
garth285 is offline
post #3 of 12 Old 01-01-2009, 07:14 PM Thread Starter
KDT4's Avatar
Tried that! Damn near did everything but stand on it and it would not budge! Even put a wrench on the allen wrench and nothing!
KDT4
KDT4 is offline
post #4 of 12 Old 01-01-2009, 07:19 PM
ricozx10r's Avatar
Images: 13
Send a message via AIM to ricozx10r
lol damn mine were easy just changed them yesterday to some pro grips. just yea take the bar ends off and an air compressor helps alot to put air under the grips and take them off easily and put the new ones on too
gen 1 10r current bike..
06 10r lowered and stretched, flashed, strapped, full brocks. sold
07 Full Muzzys exhaust,-1,4+, lowered/stretched 6in,k&n filter, powercommander,riffle man insert, block off plates, removed secondaries. sold
ricozx10r is offline
post #5 of 12 Old 01-01-2009, 07:23 PM Thread Starter
KDT4's Avatar
My ends actually look like they are molded into the bars! Hate to put too much pressure on them
KDT4
KDT4 is offline
post #6 of 12 Old 01-01-2009, 07:23 PM
Speed Freak
garth285's Avatar
Yeah I just repaired a 08 in our shop and it just took a breaker bar to get it loose. they are on there tight.
garth285 is offline
post #7 of 12 Old 01-01-2009, 08:41 PM
magzx12r's Avatar
Mine are on very tight also. I tried an allen wrench and they did not budge. I will try a bigger wrench the next time.
Mark
magzx12r is offline
post #8 of 12 Old 01-01-2009, 08:57 PM
The bar ends have lock tight on them so you must apply a lot of pressure to get them to release. Also remember when you replace them, you must use lock tight with the new screws to keep them from vibrating loose. Applying pressure won't hurt anything, I just replace mine with some new carbon ones two days ago.
filbert19 is offline
post #9 of 12 Old 01-01-2009, 09:01 PM
magzx12r's Avatar
I tried a bigger wrench and they wouldn't budge, so I broke out the impact wrench and off they came. There was no loctite on mine. I put them back on with an allen wrench and some blue loctite.
Mark
magzx12r is offline
post #10 of 12 Old 01-01-2009, 09:27 PM
nickalltogether's Avatar
I would get a set of allen sockets if you don't already have them, definitely makes jobs like this nice when you can put a 3/8th ratchet on them.
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
Need 06 zx-10r bar ends BigDally Vendors deals 6 05-04-2007 12:49 AM
New Bar Ends?!? zx-10r203 The ZX-10R 18 12-20-2006 10:39 AM
how to get bar ends off war1000 The ZX-10R 7 08-19-2006 08:27 AM
