Gen 2: 2006-2007 bad fuel pump?? - Kawasaki ZX-10R.net
post #1 of 12 Old 04-26-2011, 12:07 AM Thread Starter
TexasRider's Avatar
bad fuel pump??
07 10R, plugs changed about 2000miles ago. been running fine until this morning. Started bike, noticed it sounded like 'marbles' being spun around in tank. Bike started fine, but after idling a min or so i noticed it sounding erratic/stumbling. I let it warm up and go to take off and all she wanted to do was stumble and sputter until i got past 4-4500rpms. Higher rpms she runs fine, under 4000rpm or pulling away from a dead stop she acts like she wants to stall and runs pretty rough. At first I thought i got a tank of bad gas, but wouldnt it act up all thru the rpm range with bad gas? havent had the tank off since changing the plugs (done at a local shop) so im not thinking pinched lines. Any ideas on fuel pump? could the plugs take a shit in 2000 miles??
TexasRider is offline
post #2 of 12 Old 04-26-2011, 12:13 AM
Gen2 Ripper
neverendingmods's Avatar
Plugs after 2k unlikely. The fuel pump has 2 built in fuel filters. They do clog but usually after quite a few k miles. Try draining the tank of gas and put fresh gas in 1st before pulling the pump. Worth a shot.
You didn't fill up while the tanker truck was filling the stations tanks, did you? I clogged my cars fuel filter becAUSE THE TANKER TRUCK STIRS UP ALL THE SHIT AT BOTTOM OF STATION TANKS.
neverendingmods is offline
post #3 of 12 Old 04-26-2011, 03:42 AM
filthy phil's Avatar
wow, i'll remember that one
filthy phil is offline
post #4 of 12 Old 04-26-2011, 04:29 AM
BANNED
it's not the plugs, not very likely after 2k miles, I don't think it's the pump either, it would get worse with more rpms and more load not opposite
hellboytt is offline
post #5 of 12 Old 04-26-2011, 04:34 AM
BANNED
It almost sounds to me like it's dumping too much fuel, and it would clear up with more rpms. Since I just had my tank off I believe it's a returnless fuel system, so there has to be a controller for the fuel pump to keep the same pressure in the fuel rail.
post #6 of 12 Old 04-26-2011, 04:35 AM
BANNED
Check for vacuum leaks if they had the air box of off the engine, and do you have a pc3 or anything like that, it could also be going bad.
post #7 of 12 Old 04-26-2011, 04:42 AM
BANNED
I bet it's the fuel pressure regulator inside the tank that went bad
post #8 of 12 Old 04-26-2011, 06:26 AM Thread Starter
TexasRider's Avatar
No..truck wasnt there when I filled up. Ive know others thet got clogged filters due to that one. Bike has about 33xxx miles...
They had the airbox off yea, but like i said, its been a few thousand miles since and its run great til now. I do have a pc3..other than unhooking it, is there another way to check it?
post #9 of 12 Old 04-29-2011, 08:51 AM Thread Starter
TexasRider's Avatar
UPDATE...ok..after checking a few small things..coils on snug, plugs tight, wires hooked to packs, vacuum lines, i fired it up..still having the problem. When bike was at temp..i sprayed each header tube with water...1,3, and 4 steamed and dried instantly..#2 took a sec or 2 to dry. So..i hit each intake with some carb cleaner...1,3 and 4 stumbled and the idle dropped when sprayed, #2 didnt change much rpm at all. I have noticed though...when I first fire up the bike, and put in gear...theres no problem..no hesitation/stumble. Seems to be when it warms up is when the problem comes up....like over 145-150*. Could a plug be bad after only 2000 miles? Possible coil pack? I gave tomorrow off and im planning on switchin the coils between #2 and #3 to see if the problem follows. Any other ideas/suggestions?
post #10 of 12 Old 04-29-2011, 09:22 AM
^^No Bike Bum^^
cbolton69's Avatar
Send a message via Yahoo to cbolton69
good idea... swap the coils and retest.... if nothing changes, try changing that #2 plug.. if that dont do it maybe the #2 throttle body is having an issue...
good luck.. keep us posted
cbolton69 is offline
Removed tank, fuel pump trickling fuel constant neverendingmods Performance and Tech 9 07-21-2019 07:13 PM
Fuel Injectors and Fuel Pump Crazi Parts, Gear and Accessories 0 10-21-2009 08:42 PM
fuel pump npicolo2 Performance and Tech 0 01-01-2009 02:42 PM
Fuel pump gone...inline pump and regulator? bugman53 Performance and Tech 15 05-18-2008 11:39 AM
WTB Fuel tank/Fuel pump bellevuetlr Wanted: Buy or Trade 2 12-13-2005 08:43 AM
