Is backfiring bad ? - Kawasaki ZX-10R.net
post #1 of 33 Old 04-10-2008, 09:46 AM Thread Starter
Is backfiring bad ?
After pipes / decat / air filter / exhaust valve open / tre my bike backfires on run down... not really bad but a long series of pops.
I heard the block off plate mod fixes this... but tbh as it offers no gains in power im not to keen on it.
I love the backfiring / popping on engine run down, sounds wicked... but is it bad for engine ?
Fluke is offline
post #2 of 33 Old 04-10-2008, 10:17 AM
Gang Green's Avatar
No, this popping will not hurt your engine. Just the ears of the guy behind you.
Yes the airbox modification will eliminate that. Several way to tackle that and they prolly can be searched.
Rubber Side Down!!!
"Read The Signs"
God gave Rock'N Rolll to ya, and Kawasaki too!
Gang Green is offline
post #3 of 33 Old 04-10-2008, 10:18 AM
themightymezzo's Avatar
It's basically unburnt fuel in the exhaust igniting. Not really bad for the engine. A custom map on a pc3 could help eliminate this as I've heard doing the block off plates do as well.
Supposedly the bikes always do a backfire from the factory but their exhausts are so much more quieter than aftermarket you dont' really notice it.
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
post #4 of 33 Old 04-10-2008, 10:23 AM
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
post #5 of 33 Old 04-10-2008, 10:30 AM Thread Starter
thanks guys, ill leave it as it is then, as i love the sound :)
Fluke is offline
post #6 of 33 Old 04-10-2008, 10:38 AM
OneSLOW10's Avatar
Yea the sound of back firing is pretty freakin cool if I must say so myself. It's like your so proud of your lilttle toy when it does that
Picture PETER from Family Guy, when he sits there laughing and clapping his hands like a retard when he thinks the news caster is his dad. That's me
post #7 of 33 Old 04-10-2008, 10:47 AM
post #8 of 33 Old 04-10-2008, 10:50 AM
or10r's Avatar
If your gonna do a pcIII you wont get the proper air/fuel reading with the smog pump hooked up. The smog mod is really easy, if you want to do the mod here is a great wayhttp://youtube.com/watch?v=RIqSvXDb8GA
or10r is offline
post #9 of 33 Old 04-10-2008, 10:52 AM
Drain Fade's Avatar
+2...I have the same setup +a PCIII and smog blog off. I have no backfiring at all.
~Drain Fade
'06 Ebony Black, Supersonic Sport Tourer
A ton of shit....I want the farkles of a Gold Wing on a 150HP bike just over 400lbs ;)
Have a VFR, ZX9R or ZX10R, check out http://drainfade.com
Drain Fade is offline
post #10 of 33 Old 04-10-2008, 10:55 AM
Drain Fade's Avatar
Total overkill...all you need is a small length of 3/8in. fuel line for zx10R smog plates...it costs less than $2 and works as well as a complete block off kit. You only need JB Weld if you can't get a rubber hose between your cover (which I had to do on my VFR).
~Drain Fade
Backfiring 04ZX10 The ZX-10R 12 10-02-2006 03:02 AM
Excessive backfiring... Older Guy The ZX-10R 4 04-25-2006 09:26 PM
Question about backfiring lunitk The ZX-10R 30 04-03-2006 11:09 PM
my 10R is backfiring Meltz The ZX-10R 22 09-16-2004 09:25 AM
backfiring on deceleration 44 The ZX-10R 18 07-15-2004 05:21 AM
