backfiring after cat delete - Kawasaki ZX-10R.net
post #1 of 6 Old 07-26-2010, 04:32 PM Thread Starter
garcia2389's Avatar
I have an 07 zx-10r, I have 2 bros. slip on exhaust and PCIII with the premade map for that exhaust. I recently put a gutted cat on in place of the original cat and now on decel in the 2000-3000 rpm range i get an occasional backfire that shoots flames and is one loud pop. I'm assuming I am running rich in this rpm range at 0-2% throttle, So I tried adjusting those cells via the power commander and I subtracted about 2-3 from each and it still does it. I was told also to run a premade map for a full dual exhaust, tried it and still backfires. Anyone know what I can do to eliminate this backfiring? I'm hesitant to keep subtracting from those cells because I don't want to run to lean and ruin any internals... thanks for the advice
2007 Kawasaki zx-10r SE (sold)
2006 Kawasaki zx-6r 636 (stunt bike)
garcia2389 is offline
post #2 of 6 Old 07-26-2010, 04:46 PM
SkyDork's Avatar
This is typical of after market systems. I would stop screwing with the map and put it back to the original settings if you can't get a custom tune on it. You need to get rid of the AIS (air injection system). Buy some block-off plates or cap the hoses on the valve cover and remove the valving and hoses. Plenty of how-to threads on here if you search for 'AIS' or 'smog removal'.
#WordCrimes
SkyDork is offline
post #3 of 6 Old 07-26-2010, 04:54 PM Thread Starter
garcia2389's Avatar
alright thank you, the map is currently at the premade one for the slip on exhaust, I will try this AIS removal soon
post #4 of 6 Old 07-26-2010, 05:33 PM
Dark_'s Avatar
The AIS will certainly help remove some if not all of the popping.
Definitely do not make changes to a map if you aren't monitoring the a/f, even though small changes are relatively insignificant it's still better to be safe rather than sorry.
-Ryan
06 ZX10r
Dark_ is offline
post #5 of 6 Old 07-26-2010, 05:46 PM Thread Starter
garcia2389's Avatar
yea thats what I figured
post #6 of 6 Old 07-26-2010, 05:47 PM Thread Starter
garcia2389's Avatar
So I can just get the smog block off plates put those in and then cap the 5/8 line?
Is backfiring bad ? Fluke Performance and Tech 32 04-28-2008 01:18 PM
Backfiring....Answer!! vjhils Performance and Tech 15 12-04-2007 04:30 AM
Backfiring 04ZX10 The ZX-10R 12 10-02-2006 03:02 AM
Excessive backfiring... Older Guy The ZX-10R 4 04-25-2006 09:26 PM
my 10R is backfiring Meltz The ZX-10R 22 09-16-2004 09:25 AM
