back firing anyone? - Kawasaki ZX-10R.net
post #1 of 18 Old 07-20-2005, 12:01 PM Thread Starter
ballzman's Avatar
back firing anyone?
I'm brand new to the forum so I would like to say hello.
I have an 05 and I am on my 2nd 10R. I purchased my 05 after totalling my 04. Wow what a bike these things are. After I wrecked my 04 I really didn't even consider any other type of bike besides the 10R...it's an automatic decision for me. After getting my new bike broken in I started to notice that it back fires significantly more than my old bike. The most noticable is at higher rpm's when your on and off the gas. Does anyone know if this is normal. I have a Yoshimura slip on and a just installed a PCIII to correct it but it still does it. I should also note that my new bike lacks power that my 04 had. If any one has suggestions I would appreciate any input. I also must say that I did the 600 mile service myself and didn't do anything other than re-torque all my nuts and bolts and change my oil...did I maybe miss something? Thanks again for any input and I look forward to being a member!
ballzman is offline
post #2 of 18 Old 07-20-2005, 12:19 PM
Sounds like the PCIII was dialed in wrong. Can you double check it?
FukNRekd is offline
post #3 of 18 Old 07-20-2005, 12:49 PM
eric's Avatar
get a new map.
eric is offline
post #4 of 18 Old 07-20-2005, 03:33 PM
I think he said that it was backfiring BEFORE he put the PCIII on, He put the PCIII on in hopes that it would help.
extremelean is offline
post #5 of 18 Old 07-20-2005, 03:44 PM
phastone's Avatar
You'll never get rid of all the backfiring, but if you have a lot then a better fuel map would help.
phastone is offline
post #6 of 18 Old 07-20-2005, 03:54 PM
Ara
LE Post Whore
Ara's Avatar
Or you could try some block off plates.
Ara is offline
post #7 of 18 Old 07-20-2005, 04:59 PM
Backfiring can also be caused or at least agrivated by air leaking into the exhaust can.
swjohnsey is offline
post #8 of 18 Old 07-20-2005, 05:01 PM
Ara
LE Post Whore
Ara's Avatar
Well, to add to that, if the pair (or KLEEN or w/e Kawi calls them) valves are not blocked off, not only is air leaking into the exhaust, it is being injected!
Ara is offline
post #9 of 18 Old 07-20-2005, 06:57 PM
iroman's Avatar
I had the Kleen system removed and did not install block-off plates and I do not have any backfiring. If you removed the Kleen sys, that should've taken care of the backfire, if you haven't remove it. If already removed, check for leaks.
I also disconnected the butterfly valve, don't think that has anything to do with backfiring, but my bike use to backfire a lot before I got a custom map and did the other things I mention above and it hasn't backfired once since.
iroman is offline
post #10 of 18 Old 07-21-2005, 12:04 AM
no backfiing now,,, never did,,,, but we'll see after all my mods this weekend,,, cross your fingers
AtomAnt is offline
ZX-10R tail decals back on... El Diablo The ZX-10R 29 05-20-2007 08:19 AM
My bike is back - Pics inside crispin The ZX-10R 63 03-24-2005 11:47 PM
Bring Back Loudon cbrf41999 Race and Stunt 8 01-21-2005 09:57 AM
Back Protectors hillcountry10r The ZX-10R 36 01-06-2005 07:03 AM
RedElk's ZX10R Ride and Adventure review swft The ZX-10R 11 03-11-2004 01:24 PM
