Axle problems? - Kawasaki ZX-10R.net
post #1 of 5 Old 07-30-2010, 05:22 PM Thread Starter
Axle problems?
I am in the process of replacing my bent front rim (only a slight bend, causes a small vibration) and have heard that a damaged rim can also damage the axle. Can anyone confirm this?
Scott10r is offline
post #2 of 5 Old 07-31-2010, 10:14 AM Thread Starter
Anyone out there to put my fears to rest, or confirm them?
Scott10r is offline
post #3 of 5 Old 07-31-2010, 06:51 PM
BANNED
You should be able to check it with a straight edge. Or take it to a shop and have them use a wheel balancer and a runout gauge.
MagicMavis is offline
post #4 of 5 Old 07-31-2010, 07:28 PM
Quick10's Avatar
Yes it can happen, I bent the lip on my old ZX9 and the axle was also bent in the process.
Originally Posted by NinjeR View Post
I'm glad I'm a stripper, the money keeps coming in! lol
Quick10 is offline
post #5 of 5 Old 07-31-2010, 11:11 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
I would think you'd have to whack the piss outta the rim pretty good to bend the axle though. roll that sucker on a table top and see if it wobbles? i've done this with fork tubes in the past and it worked good enough.
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
Looking For 08 front Axle 9R to 10R Wanted: Buy or Trade 5 09-21-2009 07:53 PM
Back wheel problems ??? g-pack problems ???? Arby The ZX-10R 2 08-04-2009 08:01 PM
Rear axle nut ? jezzolo Performance and Tech 2 01-02-2008 06:14 PM
Axle Lube BigDally Performance and Tech 22 01-04-2007 06:19 PM
Axle Nut Pin BIKEMIKE Performance and Tech 15 04-13-2005 10:02 PM
