Average temps moving and in traffic? - Kawasaki ZX-10R.net
post #1 of 24 Old 07-27-2006, 02:30 PM Thread Starter
GreenGoblin's Avatar
Mine usually stays between 160 and 180 while riding. Today while riding through town I hit 5 red lights in a row, at the last one my temp was 243!! So hot my temp gauge was flashing. I'm even using engine ice. Is this normal? It cooled off as soon as I got going.
GreenGoblin is offline
post #2 of 24 Old 07-27-2006, 02:50 PM
sxi
sxi's Avatar
Images: 19
I am not sure what the norm is but last weekend mine went up to 220 degrees sitting at a stoplight, but it was a very hot day 100+ Degrees. As soon as I started moving again it dropped down to 190 Degrees…
sxi is offline
post #3 of 24 Old 07-27-2006, 03:21 PM Thread Starter
I was reading some other threads on temps. Burping your cooling system? Is that filling it up to the top then bumping it over a few times to circulate the coolant and then adding more?
post #4 of 24 Old 07-27-2006, 03:36 PM
Post Whore
1killer1liter's Avatar
Images: 11
Mine never gets over 220 at a stop light in 103 weather. As soon as the fan kicks on it goes down to 214 or so. I just have regular old antifreeze. You may need to burp the cooling system. Do a search for how to do that.
I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didnt blow a seam on your nugget box.
1killer1liter is offline
post #5 of 24 Old 09-05-2006, 10:38 PM
jckelsey's Avatar
Send a message via MSN to jckelsey
Sat in construction on a killer day for almost an hour, temp never went over 221.
jckelsey is offline
post #6 of 24 Old 09-05-2006, 11:04 PM
Accountant in training.
Deer Elk's Avatar
I don't think mine has ever been over 210. I think that is where the fan comes on....
On my way to work in the mornings (mid 50s) it runs about 150. On the way home (low 70s) it runs about 165...
Hotter days, and it will obviously run hotter. But even in stop and go traffic, I don't think I've ever seen it go over 210. Fan kicks on and cools it to 200 or so... And in 90 degree days with high humidity, I think it stays in the mid 170s even at freeway speeds in 6th gear.
Chris
Deer Elk is offline
post #7 of 24 Old 09-05-2006, 11:17 PM
blackisfaster's Avatar
Sorry but if you let your bike idle for an hour it's time for a new engine
A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort.
2006 ZX10R (Black)
blackisfaster is offline
post #8 of 24 Old 09-06-2006, 12:12 AM
BANNED
My buddies 10 gets up to almost 240 regularly after cooling fan switch, extra blade fan, engine Ice with a full muzzy and pc3 and dynoed 175 but, he runs really rich. I mean he blows smoke all the time. Mine has pc3, slip on, tre, and map, it ran about 225 to 235 but, after I used Redline's Water Wetter I never get above 214!!
Suzuk1ki11a is offline
post #9 of 24 Old 09-06-2006, 12:26 AM
conspiracy's Avatar
That is above normal boss! I would have a good look at it. If its under warranty I would bring it in. These bike are designed to withstand any conditions in this planet I don't care where. It should'nt overheat like that.
conspiracy is offline
post #10 of 24 Old 09-06-2006, 05:14 AM
On my 2006 after gutting the cat, having the entire exhaust coated inside and out(high heat black ceramic), wrapping the cat on top of the coating w/black heat wrap(since it sits a 1/2 inch under the oil pan), I run a 1/2 bottle of water wetter and Amsoil 10/40 my bike runs 140-145 on the highway, 150 on the dyno, 180-195 in traffic. Before the mods I would see 10-15 degrees higher in all situations. Thermal management rules.
Curt Brown
2006 ZX-10r, Yellow, Akropovic Carbon Slip-ons, PCIII, BMC, Jet-Hot coated exhaust, Gutted CAT, Ivan's TRE, ceramic wheel bearings, Metzler M3's, and more.
http://www.cbevo.com
CBRE is offline
Temps Tread70 The Out House 23 04-12-2006 02:14 PM
Average RPM Lillfool The ZX-10R 12 05-04-2005 06:45 PM
running temps fast_orange The ZX-10R 14 04-29-2005 09:05 PM
Coolant Temps? Aaron[MA] The ZX-10R 18 10-06-2004 04:55 PM
running temps blast_off Performance and Tech 15 08-28-2004 08:15 PM
