Gen 4: 2011-2015 Attack triples ABS hardline issue - Kawasaki ZX-10R.net
post #1 of 8 Old 08-08-2015, 05:27 PM Thread Starter
I have Attack triples with "4" offset (26 degrees) and at full left it rubs the hardline to the brake junction under the lower triple. Has anyone replaced the ABS pump hardline, and with what?
Thanks in advance,
petere
peter83 is offline
post #2 of 8 Old 08-08-2015, 06:43 PM
peterd10r's Avatar
Images: 7
So Peter have you still got oem brake lines?Im guessing not if you have a/m triple clamp!I have removed oem abs lines from the pump to the front and all the junction points!to remove these fittings especially trying to crack the hard lines into all oem junctions can be testing!you have to use pipe spanners(C spanner)and even then the head of the hard pipes can round very easily!I had to use multi grips on one nut in the end so DONT try a open end spanner or dramas will occur!if you disconnect brake lines from the abs pump and leave all wiring as then you will not throw a F1 fault!tbh it's a pia removing the lines so try and remove the M6 junction bolt that hits and see if you can either swing it round a little or maybe cable tye it out of the way!just be care moving the hard alloy oem lines that you don't crimp them.
peterd10r is offline
post #3 of 8 Old 08-08-2015, 06:50 PM
peterd10r's Avatar
Images: 7
And sorry I replaced with Spiegler a/m brake lines by-passing my abs system!theres plenty of company's that supply non abs gen4 lines and I think Spiegler and Galfer do the gen4 abs!
post #4 of 8 Old 08-11-2015, 08:16 AM Thread Starter
Hi Peter,
I still have the oem brake lines and want to keep the ABS functional as I have ABS on my daily driver bike (71,300 miles on CBR600RR C-ABS) and am used to it. I have another hard line on the way and will probably have a local firm fabricate a replacement.
peter83
peter83 is offline
post #5 of 8 Old 08-11-2015, 04:07 PM
peterd10r's Avatar
Images: 7
Peter check out Galfer lines they are for abs and utilize the oem hard lines and use manifolds to connect there a/m lines to under the triples!Spiegler abs replace every line to the abs unit!every line on the gen4 abs oem system is incredibly tight at every solid alloy hose to rubber so do NOT attemp UNLESS you use 2 pipe spanners and even then its a struggle!
post #6 of 8 Old 08-22-2015, 11:57 PM Thread Starter
Just got the wheels mounted, next step is gluing stall mat to frame
peter83 is offline
post #7 of 8 Old 08-23-2015, 12:36 AM Thread Starter
Stock hardline to junction getting pinched at full left lock, picture not at full left lock.
peter83 is offline
post #8 of 8 Old 10-07-2015, 08:51 PM
shoginator's Avatar
Attack for some reason does not provide steering stops on their triples. We have used hard rubber stops attached to the frame to keep things from getting crushed. Helps in a crash big time.
shoginator is offline
Tags
abs, attack
Gen 4: ABS & aftermarket rearsets, fitment issue arc Performance and Tech 54 03-16-2015 02:10 PM
Gen 3: Attack triples, Akro slip-on, Evotech hanger, PC Ignition Module Cocky Rooster Parts, Gear and Accessories 40 08-02-2014 01:50 AM
Gen 4: 2011 ZX10 ABS light issue? speedy14 The ZX-10R 1 06-25-2014 09:14 PM
Wanted: wtb Gen 4 attack triples munroe Wanted: Buy or Trade 4 04-03-2014 01:04 AM
What should I pay OTD for a 2012 zx-10r ABS? Is ABS worthwhile? enchantor The ZX-10R 25 04-22-2012 04:01 AM
