Gen 3: 2008-2010 Attack Racing Lift Mounts install ? - Kawasaki ZX-10R.net
post #1 of 8 Old 06-25-2012, 09:49 PM Thread Starter
anaxdlere's Avatar
I just purchased a set of these for my '08 track bike. One of the spools snapped off the swingarm, so I wanted to give these a shot. Since they require to be tapped into the swingarm, I took it to my local shop to have them install them and they are saying that they don't want any part of trying to install them since the aluminum on the swingarm is so thin and the bolts have little or nothing to "bite."
Has anyone installed these on a Gen 3 and have any tips or concerns? My Woodcraft Toe Guard (Shark Fin) came with some rivet nut inserts that I wonder if would be needed for these lift mounts.
Any tips?
anaxdlere is offline
post #2 of 8 Old 06-26-2012, 01:03 PM
I bought my swing arm with them installed, so I can't comment on the installation, but those little ramps are heavenly when changing the tire. Attack isn't some shade tree mechanic shop, so any competent machine shop should be able to handle it.
Cocky Rooster is offline
post #3 of 8 Old 06-26-2012, 01:18 PM
SkyDork's Avatar
Yeah, I wouldn't want to drill holes in my swingarm either. That's way too Shervin-eske for me.
But I do believe they bolt onto the solid cast pieces at the rear of the swingarm. The forward portion and rear portion where the axle goes through are cast aluminum, solid, and then welded to the hollow beams through the center. Make sure that's where these mount up and it shouldn't be an issue drilling and tapping those areas. If its supposed to mount forward of the weldment where the axle is, then I wouldn't touch it. That shark guard mounts in that area, but there's no stress associated with that like there is with these supports.
Sounds like the shop doesn't understand the swingarm construction and how these are installed. But rightfully so, they also don't want the liability. You can eff up the arm if done incorrectly.
#WordCrimes
SkyDork is offline
post #4 of 8 Old 06-26-2012, 05:06 PM Thread Starter
anaxdlere's Avatar
I will likely just have to change the shop I take them to in order to get them installed. These guys just seemed to be a bit too skittish.
post #5 of 8 Old 06-27-2012, 08:35 AM
champ91's Avatar
Totally shootingfrom the hip, but isnt the end of the swingarm solid alum. I am talking about the end where the axel goes thru I beleive is solid. SHould be no problem drilling and tapping.
And talking from just looking at the pisture, do they even need the drill and tap. Looks like the forward bolt would bolt thru the spool mount position abd the flat part would be under the swingarm for support. Just a guess.
NESBA #456 Intermediate
champ91 is offline
post #6 of 8 Old 06-27-2012, 08:40 AM
champ91's Avatar
And if I would have paid attention to OP post, just realized you snapped off the spool mount.
champ91 is offline
post #7 of 8 Old 06-27-2012, 09:39 AM
MR ZX_R DC's Avatar
Yea that part is solid not hollow... I have that mod done to my GEN4.. You might want to find a race shop.. The photo below is from this thread https://www.zx-10r.net/forum/showthread.php?t=114582
Any tips?
MR ZX_R DC is offline
post #8 of 8 Old 06-28-2012, 06:01 PM Thread Starter
anaxdlere's Avatar
Thanks for the info. I will try to look for a more race-like shop and have them take care of it. I will try to get pics along the way to post.
Gen 1: What's the easiest way to re-install motor with bike lift? NinjeR Performance and Tech 5 03-02-2011 11:34 AM
2006 Arrow Exhaust Install - Sportbike Attack blog tylerdurden455 Pictures and Videos 26 01-15-2007 07:28 AM
Attack Racing Plastic Slims10R The Out House 4 08-23-2006 05:23 AM
Attack racing zx-10 sweetride10r The ZX-10R 27 12-15-2005 02:35 PM
Attack racing on ebay..... Alex31 The ZX-10R 0 05-09-2005 08:14 AM
