Arrow half system butterfly delete question - Kawasaki ZX-10R.net
post #1 of 9 Old 12-12-2008, 02:01 PM Thread Starter
Kawi#1 is offline
post #2 of 9 Old 12-12-2008, 02:18 PM
zx10forme's Avatar
Smile Arrow system
Originally Posted by Kawi#1 View Post
I am looking at the Arrow exhaust for my 2007 ZX10R. I like the 'half system' because it deletes the cat and has welded bung.
My question deals with the butterfly valve it also deletes. I understand it is quite easy to simply remove the cables to the valve, but leave the electronic control unit in place to avoid having the FI light illuminate constantly. Easy enough fix...
My bike is 100% stock. I do not want any aftermarket controllers at this point or have the bike dynoed. I am doing the Arrow exhaust for looks & sound only, any performance gains are a added benefit I am happy to have.
Will removing the butterfly valve without adding a fuel controller or custom tune at the same time actually decrease performance or require tuning that wouldnt otherwise be needed if I do only the slip on portion?
Essentially the quick and dirty question is on a otherwise 100% stock 07 ZX10R should I do the slip on or the half system?
I hope that I didnt leave out some important information that is needed for a acurate answer or overcomplicate the question at the same time.
Thanks for your input.
Hey Guy,it's my understanding that changing the exhaust,intake,cat,is going create a lean condition.I would recommend a fuel controller and a good map for those mods.
zx10forme is offline
post #3 of 9 Old 12-12-2008, 03:15 PM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
Im confused whats a half system??
Im guessing a slip-on?
If so id go with that just a slip on, but most dont eliminate the cat. just the butterfly valve.
the OEM system is header-cat-and y-pipe (which has the valve inside). Most slip-ons eliminate the OEM y-pipe, but some are just mufflers which leave the OEM y-pipe intact.
I think you will be ok with no mapping and a slip-on you will get some popping on decel.
Heres a link but there sold already.
https://zx-10r.net/forum/showthread.php?t=67581
www.sportbikepc.com
Sport Bike Powder Coating,LLC
06blackpearl is offline
post #4 of 9 Old 12-12-2008, 03:47 PM
drkramm's Avatar
half system is header back (everything after the header is replaced)
a slip on just replaces the mufflers
most people i know gut there cat .. me included..
so it kinda makes it a half system
i have 7k miles on my bike with gutted cats no servo and slipons and never had a problem (no fuel controller)
"Once you've tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been and there you long to return."
drkramm is offline
post #5 of 9 Old 12-12-2008, 03:57 PM
Images: 70
Kool but i always considered it full or slip on cause theres tons of systmes that are slip ons that are cat back.
www.sportbikepc.com
post #6 of 9 Old 12-12-2008, 04:33 PM
drkramm's Avatar
drkramm,
Can you tell me what you think about your set-up? How much louder was/is it, hows the power band feel compared to stock, etc?
Did the removal of the cat/valve seem to change the power curve (guessing maybe more power in high RPM with small sacrifice in low end rpm power?) or open it up throughout?
Really like to get your thoughts. I agree slip ons with cat/servo delete is all the same essentially no matter how you get there. IE gut the cat or buy the Arrow.
when i had the baffles in the mufflers it wasn't too much louder then stock but with those removed it was noticeably louder but wasn't bad at all under 8-9 grand it was fine above that it started to get loud
im sure there was a power increase but i really didn't notice it if there was other then the sound making me think i was going faster
the vavle is really only there for noise
Kool but i always considered it full or slip on cause theres tons of systems that are slip ons that are cat back.
slip ons are just the muffler and if needed a mid pipe but the mid pipe is almost always only included cause theres no way to remove just the muffler .. my 636 was like this the only flange/break in the exhaust is about 2 feet away from the muffler so they need to add a pipe that can connect to both the factory exhaust location and there own pipe
slip on is my yoshi's or any other system that literaly bolts on to the entire factory exhaust (two bros duals, ackro duals etc...)
half system would be something like the single two bros exhaust which bolts on to the cat pipe, or area p's single or ti-force etc..
a full system always has the headers it wouldn't be a full system with out headers
drkramm is offline
post #7 of 9 Old 12-12-2008, 05:30 PM
diesel10R's Avatar
I started with the half system, It comes with set of cans and y-pipe only that elminates butterfly valve only,mounts right up to stock cat,it does not include cat delete pipe, stock cat remain unless you gutt it. But later you could buy the whole collector set-up to make a full system.
ride or die!::weed :
diesel10R is offline
post #8 of 9 Old 12-13-2008, 12:07 PM
limenine's Avatar
I have the Arrow half system exactly as you described, and the bike runs just fine without retuning. I fully expected to need a PCIII because of the cat and butterfly, and I still may put one (or a Bazzaz) on in the future - but my '06 has not needed one.
For perspective, when I did exhaust on my '01 ZX9R, it needed jetting, and exhaust on my '03 ZX6RR required a PCIII to make it run right - but no issues with the Arrow on the 'ten.
limenine is offline
post #9 of 9 Old 12-13-2008, 01:07 PM
green_zx's Avatar
Send a message via AIM to green_zx
I had the arrow system with the y-pipe for awhile. I had no issues be for the pc3 with the way it ran. I did gut the cat and tune the bike. It made the most difference in the mid-range but not as much up top. So from my experience you may loss a negligible amount of low to mid range if you do not tune the bike. But overall the system works great on a stock bike.
green_zx is offline
Gen1 D&D Half System for sale 06450F Parts, Gear and Accessories 1 06-03-2008 06:19 AM
Two Bros half system , 06/07 P.Garvin Parts, Gear and Accessories 6 06-22-2007 09:11 AM
When i get my new exhaust from speed I will be sellig my sato half system topher3134 Parts, Gear and Accessories 1 06-10-2007 09:37 PM
Area P Dual Can Half System Feeler! 9R to 10R Performance and Tech 0 01-30-2007 09:02 PM
05 ZX10 Yosh tri oval SS half system for sale MINT JT10R Parts, Gear and Accessories 15 02-05-2006 03:15 PM
