Anyone used an Elka rear shock yet? - Kawasaki ZX-10R.net
post #1 of 7 Old 07-31-2007, 07:51 PM Thread Starter
ryanbz2001's Avatar
Just curious to see how the Elka rear shock compares to others. (i.e. Ohlins, Penske, etc...) Going on a 2004 ZX10.
Thanks
ryanbz2001 is offline
post #2 of 7 Old 07-31-2007, 08:57 PM
bulletr1's Avatar
Send a message via Yahoo to bulletr1
I've ridden a bike with the Elka shock on it. I think it rode pretty nice. Way better than the stock shock. But I couldn't put out for the Elka shock so I just got the Ohlins spring and put that on the stock shock. I'm pretty happy with that.
PC Frame, Swing Arm, Wheels. Gold Rear Sets, Chrome Heel Guards, Factory Pro. Vel. Stacks, PCIII, K&N Air Filter, Full Akra. Exhaust System, 525 DID Gold MVXZ Chain, HID KIT HI & LOW BEAM (6K), 1/5 Throttle Conversion, Ivan's Block Off Kit,TRE & Servo Elim. Air Box Mod, Stainless Steel Braided Lines, Blue Custom Gauge Panel, InterNatrix Paging Security Sys., Michelin Pilot Powers Tires, Barnett Clutch Springs, Custom In/Ex Cams by Web Cams, Milled Cylinder Head. 173.7RWHP
bulletr1 is offline
post #3 of 7 Old 07-31-2007, 09:50 PM
norcal10's Avatar
my bud has an elka on his 07 gsxr1000 and loves it. he had a penske first, had so-so results. his elka is much better, he says. i've no personal experince wth it, just going off what he said.
norcal10 is offline
post #4 of 7 Old 07-31-2007, 10:57 PM
SalKhan's Avatar
Send a message via AIM to SalKhan Send a message via Yahoo to SalKhan
You might want to research getting parts for it if you ever need to rebuild or update it. It doesn't happen often, but it is nice to know how available stuff is. Nothing against Elka since I've heard nothing but good things, and since I work for a dealer I have limited options to look for if I want dealer pricing... but just something to keep in mind.
That's probably why I'd personally go with Ohlins or Penske - lots of established support out there already.
Sal Khan
http://www.thelunchjournals.com - Updated 3/8/08!
SalKhan is offline
post #5 of 7 Old 08-01-2007, 02:24 AM
Rizzo's Avatar
Elka was the first aftermarket shock I have tried on the 10 and it was a night and day differance. I had it ravalved and resprung for my weight and riding style etc. with very good results. Bike hooks up a lot better and is very compliant, had to relearn the bike as my overall rear grip increased (bike before with OEM shock was too stiff and would break traction a lot easier). The guy that did all the work on the suspension for me even preferred Elkas as they were easier to setup and get dialled in. He also thought that Elka and Ohlins were the only rear aftermarket shocks worth installing before you start spending really big money on serious race kit suspension. I would say almost any rear shock though would be a good improvement over stock, just depends how much money you want to spend. Me I picked up an Elka Triple on Ebay for $650 in Austrlalia, they retail here for $1895, so I was very happy with my money spent.
Rizzo is offline
post #6 of 7 Old 08-01-2007, 02:15 PM
Supercharged Mod
Elka makes lotsa sense for us Canucks since they're locally made. A lot of the amateur racers here (i.e. those who are paying their own way!) are using Elka. Parts availability is obviously not a problem for us ...
for what it's worth I know Jeff Williams who is the rider in this picture: http://www.elkasuspension.com/road/index.html
GoFaster is offline
post #7 of 7 Old 08-10-2007, 04:41 PM
had a elka 2 way put on my 04. These can be ordered with spring to suit your weight whereas ohlins come with standard spring. There are limitations to the rebound damping but these can only really be found on track and I'm told a re valve can sort this. Overall for the money its hard to find better and I'm happy. Its not easy to deal with over 160 bhp (tuned) with revised gering on a bumpy road. Many of the 04 handling problems are down to the shock. You will not be disapointed!!
gremlin856 is offline
Elka Triple Shock FS kneedragger Parts, Gear and Accessories 13 06-28-2007 06:13 PM
WTB: Used Penske/Ohlins/Elka rear shock Cling Wanted: Buy or Trade 6 04-21-2007 03:14 AM
elka shock mr wael Performance and Tech 3 12-04-2006 05:57 AM
Elka rear shock. rocketracermike The ZX-10R 1 11-12-2006 01:39 PM
WANTED Elka shock johnnyb-21 Wanted: Buy or Trade 4 02-16-2006 04:09 PM
