Anyone use the rear shock spacer kit on the 06 yet? Or have exp with it on the 04/05 - Kawasaki ZX-10R.net
post #1 of 14 Old 08-08-2006, 11:48 AM Thread Starter
brian0128's Avatar
A friend of mine (kneedragger_13) wants to raise his rear by 5mm. We weren't sure of the spacer size and so I went onto the Kaw site and saw that there is an optional spacer kit shown. The optional spacers are in a horseshoe shape, so it looks like it would be much easier to install since you wouldn't have to take the bolt out of the frame. Has anyone used these? What holds them in? Also, does anyone know if these can be ordered yet and if so, what size the spacers are that come in the kit.
Here is the link of the parts that I'm looking at.
http://www.kawasaki.com/html/default...D=2&intParts=1
It says the regular washer is 16.5X26X6 in size. Would I be correct in assuming that is 16.5 inside diameter, 26 outside and 6mm in height? The spacer kit number is 92026-0057 and I'm looking at the picture trying to figure out what holds the spacer in place?
brian0128 is offline
post #2 of 14 Old 08-08-2006, 10:40 PM
The spacer kit is expensive. I just ordered a couple of washers.
swjohnsey is offline
post #3 of 14 Old 08-09-2006, 12:24 AM
I use the spacer kit on my 636 (basically same parts minus one 10r-specific piece, cost is 1/2 of 10r kit). Next to completely reworking your suspension, it's the best thing you can do for the bike's stability & drive.
SuicideMachine is offline
post #4 of 14 Old 08-09-2006, 01:04 AM
kneedragger_13's Avatar
Send a message via Yahoo to kneedragger_13
Hey all....I am the one looking to see if I need this kit. How much is it? Is it worth the money or I can just have a guy make me a 5mm round washer and have it the next day. Looks like it would be easier switching out the ones from the kit Also will those U shaped washers fall out at all?
kneedragger_13 is offline
post #5 of 14 Old 08-09-2006, 10:42 AM Thread Starter
brian0128's Avatar
This still isn't going to make you any faster!
post #6 of 14 Old 08-09-2006, 10:44 AM
zx10Duran's Avatar
I just used a couple washers...total cost $2.11
zx10Duran is offline
post #7 of 14 Old 08-09-2006, 12:11 PM Thread Starter
brian0128's Avatar
Would I be correct in assuming that is 16.5 inside diameter, 26 outside and 6mm in height was the factory size?
post #8 of 14 Old 08-09-2006, 01:33 PM
No....but it will make me quicker Besides, I have to stay back so you have a taillight to follow
post #9 of 14 Old 08-09-2006, 01:37 PM
SkyDork's Avatar
The spacer kit is like $174 for some fancy bent peices of aluminum. You can find a nut at the local hardware store to do this same thing for $3 or less. It will be able to be tuned much finer using a nut, and it'll be more secure.
#WordCrimes
SkyDork is offline
post #10 of 14 Old 08-09-2006, 01:49 PM
Wow!!! now that is expensive.... Well, after hearing that price and chatting with niklasinorr, I am just going to have a spacer made.
Rear Shock???????????? SP8 Performance and Tech 19 01-26-2005 04:35 AM
Rear Shock Again ZX10BURNER Performance and Tech 4 01-13-2005 06:16 PM
WTB '03 and up 6R/6RR or ZX-10R rear shock pacmann33 Parts, Gear and Accessories 5 10-02-2004 01:24 PM
Spacer on Rear Suspension Mounting! vane The ZX-10R 2 06-05-2004 06:05 PM
