anyone use the raceing exhaust cam as intake? - Kawasaki ZX-10R.net
post #1 of 6 Old 03-22-2008, 01:58 PM Thread Starter
avdigigeek's Avatar
I have an exahst cam I'm thinking about what to do with it?
I've heard some use the stocker exhuast as the intake cam?
The race intake is so hard to come by these days not sure of any other solution.
any thoughts? am I totaly retarded ?
Thanks in advance
avdigigeek is offline
post #2 of 6 Old 03-22-2008, 03:55 PM
bodyglove's Avatar
Images: 15
Send a message via MSN to bodyglove
it will work , but you will loose power because the stock intake has more lift than the stock exhaust cam so its not worth the swap
bodyglove is offline
post #3 of 6 Old 03-22-2008, 07:37 PM Thread Starter
avdigigeek's Avatar
What about the race exhaust cam is that smaller then the stocker ?
post #4 of 6 Old 03-23-2008, 07:19 PM
bodyglove's Avatar
Images: 15
Stock intake cam 9.2MM lift
Race intake cam 9.7MM lift
Stock Exhaust Cam 8.5MM lift
Race Exhaust cam 8.0MM lift
post #5 of 6 Old 03-23-2008, 09:20 PM
jimbob8915's Avatar
Anybody done a race intake and stock intake for exhaust?
jimbob8915 is offline
post #6 of 6 Old 03-23-2008, 09:59 PM
BANNED
You can't use the intake cam on the exhaust side. The reason for that is fuel injection. The computer must know if the piston going up is on the exhaust stroke or the compression stroke. How it knows this is by a sensor on the exhaust cam side. The exhaust cam has to be able to trip the sensor. There is no provisions for this on the intake cams.
An enterprising individual might be able to machine it though. Most likely out of the abilites of most home mechanics.
So it wouldnt be a simple bolt on.
JJ
JimmyJam is offline
intake springs on exhaust valves 05 zx10r speeddemon Performance and Tech 1 03-18-2008 10:40 PM
Intake & exhaust cam specs 11outa10 Performance and Tech 11 12-05-2007 07:40 AM
stock intake cam for exhaust jimbob8915 Performance and Tech 9 08-22-2007 10:50 PM
06 Intake race intake HP & cams specs 11outa10 Performance and Tech 10 12-12-2006 03:57 PM
Thin head gasket, bigger intake and exhaust cams, 1killer1liter The Out House 12 04-28-2006 07:12 PM
