Anyone use HRC Rear Brake Res Tube system? - Kawasaki ZX-10R.net
post #1 of 9 Old 10-30-2008, 08:44 PM Thread Starter
Hear green tube sweats brake fluid??? ANy one have any experience with these kits?
SAkI is offline
post #2 of 9 Old 10-31-2008, 11:04 PM
Hooked on Phonics dude...
madryan is offline
post #3 of 9 Old 11-01-2008, 04:04 PM
Ronnie@South Seas's Avatar
I have it and it works great!!! I will take a pic and post it up. I had to concerns when I first installed it, I thought I would have to add fluid often, and the heat from the exhaust pipe might be a problem. Heat is not a problem at all and I have not filled it up once since install (3 months).
I do use my rear brake often.
[email protected] Seas is offline
post #4 of 9 Old 11-01-2008, 04:15 PM Thread Starter
Thanks pics and input is appreciated. Want to install but want to ensure no problems with it.
SAkI is offline
post #5 of 9 Old 11-01-2008, 04:41 PM
Here are a couple of pics. Like I said, I was worried about the heat from my exhaust pipe but it has not been a problem so far. I still keep my eye on it though.
ID:	80747   Click image for larger version
post #6 of 9 Old 11-03-2008, 03:06 AM
booken's Avatar
I tried it and it did weep brake fluid. So I cut down the original rubber tubing. Sure I can't see how much fluid is there but it doesn't leak any longer
If you gotta ask you can't afford it.
booken is offline
post #7 of 9 Old 11-03-2008, 10:17 AM Thread Starter
Ronnie, no pics?
SAkI is offline
post #8 of 9 Old 11-03-2008, 01:07 PM
There up now!!
post #9 of 9 Old 11-03-2008, 01:22 PM
usman's Avatar
Images: 13
i made my own, all i did was remove the rear brake cylinder, and plug it with a wider screw, just screwed it on, and then zip tied it. works like a charm, track tested and approved.
old man ran off on his wheelchair
theazzman.com (my blog)
usman is offline
WTS ZX10R Brake system riding4life162 Parts, Gear and Accessories 0 01-28-2008 03:01 AM
Brembo Brake system riding4life162 General Motorcycle Discussions 4 01-23-2008 09:59 PM
Rear brake spring with Vortex rear sets? Puckfu Performance and Tech 2 10-26-2007 04:49 PM
Rear Fender and mesh insert for ram air tube (04-05) booneylander Parts, Gear and Accessories 0 08-10-2007 08:14 AM
Attack rear set question-rear brake light switch? steves87 The ZX-10R 35 10-09-2006 04:47 PM
