Anyone remove their kickstand and switch? - Kawasaki ZX-10R.net
post #1 of 5 Old 08-03-2005, 01:52 AM Thread Starter
yehzx10r's Avatar
Looking to remove the kickstand for the track, but what do I do about the kickstand safety switch? Can anyone post pictures? Thanks!
yehzx10r is offline
post #2 of 5 Old 08-03-2005, 02:17 AM
MIA Post Whore
miykl's Avatar
removed stock kickstand to install Sato Ti KS. Removed KS switch. Gained 15 HP!!!
2011 Ninja 1K street
2004 636 track
miykl is offline
post #3 of 5 Old 08-03-2005, 03:33 AM
Just zip tie it in the up position.
BIKEMIKE is offline
post #4 of 5 Old 08-03-2005, 03:51 AM
1rocket69's Avatar
Location: Used to be Candler, NC/ Then HELL in Del Rio, Tx/ Now Blaine, WA
I haven't removed the one on my 10 yet but I did on my old 9R when going to the track. When I took it off I just cut the wires for the sensor right above the CS sprocket area and put two plugs(male/female) on each end so I could just plug it back together for riding on the street, if I remember right(I didn't make it to the track last year,been a while) when I took it off, the plug that was still on the bike I had a jumper plug/wire that I stuck in to make the circuit complete, the way it works was there's two wires and when you put the kickstand down, it(the kickstand switch) breaks the circuit then when it up it completes the circuit letting it start; just plug one wire back into the other lead and it thinks the stand is up
Like i said i've not done it yet on this bike but it should be the same
Liberal-- A person who is so open minded that their brains have fallen out.
1rocket69 is offline
post #5 of 5 Old 08-03-2005, 07:02 AM
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
I just did mine. I took all the kickstand assembly off and cut the wires and soldered them together. That way it makes it think the kickstand is always up whether it is on the bike or not. If you do this though you can only start the bike in nuetral or so I have been told. no biggie though.
zx10ragentblack is offline
